Starwind Virtual SAN Free vs remote web monitoring
serhiogo
Thu Aug 16, 2018 1:07 pm
Hello collegues.
I'm using Starwind Virtual SAN Free v8.0.0 (Build 12166). I'm trying to use the remote web monitoring as described here: http://darklight.pro/how-to-monitor-sta ... b-browser/ but my both nodes are refusing PHP connection attempts. As I can see with sniffer, the storage node answers "104 Command rejected by the server" to the login attempts. I get the same error while attempting to emulate this session via telnet to TCP port 3261:
StarWind Virtual SAN v8.0.0 (Build 12166, [SwSAN], Win64)
Copyright (c) StarWind Software 2003-2017. All rights reserved.
login root starwind
104 Command rejected by the server.
Invalid version of Control Connection Protocol. Minimum supported version is: 1.0.0
Is it a Free edition limitation or I'm doing something wrong?
WBR, SerhioGo.
Oleg(staff)
Fri Aug 17, 2018 10:12 am
Hi serhiogo,
Unfortunately, this option is not available with Starwind Virtual SAN Free.
serhiogo
Fri Aug 17, 2018 10:29 am
Oleg(staff) wrote:Hi serhiogo,
OK, it's clear, thank you for reply.
Michael (staff)
Mon Oct 08, 2018 8:36 am
Thank you as well!
denkteich
Sat Aug 03, 2019 2:04 pm
Hi all,
sorry to warm up the older thread.
Is the telnet login available in the NFR Version of the sphere aplliances?
I only get:
StarWind Virtual Storage Appliance v8.0.0 (Build 12859, [SwVSA], Win64)
login root starwind
Any suggestion?
cheers
.d
Oleg(staff)
Wed Aug 07, 2019 11:48 am
Hi denkteich,
StarWindX is available in StarWind VSAN for vSphere. You should install Integration Component Library on the machine you are managing from.
