$server = New-SWServer -host 172.17.62.11 -port 3261 -user root -password starwind
$server.Connect()
$firstNode = new-Object Node
$firstNode.HostName = "172.17.62.11"
$firstNode.ImagePath = "My computer\D\temp"
$firstNode.ImageName = "masterImg21"
$firstNode.Size = 12
$firstNode.TargetAlias = "targetha21"
$firstNode.AutoSynch = $true
$firstNode.SyncInterface = "#p2=192.168.39.12:3260"
$firstNode.HBInterface = "#p2=172.17.62.12:3260"
$firstNode.PoolName = "default_pool"
$firstNode.SectorSize = 4096
# 'SerialID' should be between 16 and 31 symbols. If it not specified StarWind Service will generate it.
# Note: Second node always has the same serial ID. You do not need to specify it for second node
$firstNode.SerialID = "4f30384e672654a2fbe5dc19c269be"
$secondNode = new-Object Node
$secondNode.HostName = "172.17.62.12"
$secondNode.HostPort = "3261"
$secondNode.Login = "root"
$secondNode.ImagePath = "My computer\D\temp"
$secondNode.ImageName = "partnerImg22"
$secondNode.Size = 12
$secondNode.TargetAlias = "partnerha22"
$secondNode.AutoSynch = $true
$secondNode.SyncInterface = "#p1=192.168.39.11:3260"
$secondNode.HBInterface = "#p1=172.17.62.11:3260"
7/7 22:25:10.817 2188 IMG: ImageFile_CreateRawFile: File 'D:\temp\masterImg21.img', size: 12 MB, flags 0x240...
7/7 22:25:10.817 2188 IMG: ImageFile_CreateRawFile: Using SetFileValidData...
7/7 22:25:10.817 2188 IMG: ImageFile_CreateRawFile: Zero out only the first and the last 1MB of the image.
7/7 22:25:10.817 2188 IMG: ImageFile_CreateRawFile: WARNING: This can damage security if the file image is exported directly to untrusted clients!
7/7 22:25:10.848 2188 IMG: ImageFile_CreateRawFile: File 'D:\temp\masterImg21.img' created. Total elapsed time = 0 sec.
7/7 22:25:10.880 2188 Common: *** sw_common::Sw_Disk_Header::create: (file: D:\temp\masterImg21.swdsk, cached: no).
7/7 22:25:10.880 2188 Common: *** sw_common::Sw_Disk_Header::create: creation parameters:
- device name: (null);
- plugin name: imagefile;
- storage path: My computer\D\temp\masterImg21.img;
- device LUN: 0;
- device size: 12;
- storage offset: 0;
- serial Id: (null);
- EUI-64: (null);
- vendor id: STARWIND;
- product id: STARWIND ;
- revision level: 0001.
L1 cache parameters:
- mode: none;
- size: 64;
- flags: 0;
- expiration time: 0;
- high watermark: 0;
- low watermark: 0.
L2 cache parameters:
- mode: (null);
- storage: (null);
- size: 0;
- flags: 0;
- low watermark: 0.
7/7 22:25:10.880 2188 Common: *** sw_common::Sw_XML_Storage_Impl::str2type: The "(null)" type is not supported.
7/7 22:25:10.927 2188 Common: sw_common::Sw_Disk_Header::open: (file: D:\temp\masterImg21.swdsk, readonly: no).
7/7 22:25:10.942 1044 SCSI: : parameter 'DeviceHeaderPath', value 'My computer\D\temp\masterImg21.swdsk'.
7/7 22:25:10.942 1044 SCSI: : parameter 'file', value 'My computer\D\temp\masterImg21.swdsk'.
7/7 22:25:10.942 1044 IMG: SscPort_Create: Parsing parameters from control connection:
7/7 22:25:10.942 1044 IMG: SscPort_Create: Header path parsed to 'D:\temp\masterImg21.swdsk'.
7/7 22:25:10.942 1044 IMG: addParameter: Parameter processed (add): DeviceHeaderPathPhysical = "D:\temp\masterImg21.swdsk"
7/7 22:25:10.942 1044 IMG: addParameter: Parameter processed (add): file = "My computer\D\temp\masterImg21.swdsk"
7/7 22:25:10.942 1044 Common: sw_common::Sw_Disk_Header::open: (file: D:\temp\masterImg21.swdsk, readonly: no).
7/7 22:25:10.942 1044 IMG: SscPort_Create: Parsing the Device Header File 'D:\temp\masterImg21.swdsk':
7/7 22:25:10.942 1044 IMG: addParameter: Parameter processed (update): file = "My computer\D\temp\masterImg21.swdsk" -> "My computer\D\temp\masterImg21.img"
7/7 22:25:10.942 1044 IMG: addParameter: Parameter processed (add): SectorSize = "4096"
7/7 22:25:10.942 1044 IMG: addParameter: Parameter processed (add): SerialId = "1F013877895289EA"
7/7 22:25:10.942 1044 IMG: addParameter: Parameter processed (add): eui64 = "1F013877895289EA"
7/7 22:25:10.942 1044 IMG: addParameter: Parameter processed (update): SerialId = "1F013877895289EA" -> "1F013877895289EA"
7/7 22:25:10.942 1044 IMG: addParameter: Parameter processed (update): eui64 = "1F013877895289EA" -> "1F013877895289EA"
7/7 22:25:10.942 1044 IMG: SscPort_Create: Opening device 'imagefile9', image file 'My computer\D\temp\masterImg21.img', buffering=0, async=1, readonly=0.
7/7 22:25:10.942 1044 IMG: ImageFile_Create: 'D:\temp\masterImg21.img': type 0, geometry: sct 16, trks 32, cyl 6, TotalSectors: 3072, SectorSize: 4096, PhySectorSize: 4096
7/7 22:25:10.942 1044 IMG: ImageFile_Create: VendorId 'STARWIND', ProductId 'STARWIND ', Revision '0001', Serial '1F013877895289EA'
7/7 22:25:10.942 1044 IMG: ImageFile_Create: 'D:\temp\masterImg21.img': disk is HDD, UNMAP not supported.
7/7 22:25:10.942 1044 SCSI: iScsiDevice::updateDeviceIds: EUI64 retrieved: 1F013877895289EA (hex)
7/7 22:25:10.942 1044 SCSI: iScsiDevice::updateDeviceIds: SerialID retrieved: 1F013877895289EA
7/7 22:25:10.942 1044 SCSI: iScsiDevice::updateDiskSize: Disk 'imagefile9' (12 MB)
7/7 22:25:10.942 2188 conf: ConfCommand::processNew: Device [0x000001DAB074ADC0] 'imagefile9' has been created.
The generated image device header has the following. The sector size seems to be correctly set to 4096 per the script.
<?xml version="1.0" encoding="UTF-8"?>
<header signature="StarWind" version="1.0">
<device active="true" plugin="imagefile" name="imagefile">
<storages>
<storage id="1" type="device" name="imagefile" lun="0x0">
<interval size="12" units="MB"/>
<inquiry>
<serial_id>1F013877895289EA</serial_id>
<vendor id="STARWIND"/>
<product id="STARWIND " revision="0001"/>
<eui_64>1F013877895289EA</eui_64>
</inquiry>
<geometry>
<sector size="4096" psize="4096"/>
<track sectors="16"/>
<cylinder tracks="32" count="6"/>
</geometry>
</storage>
</storages>
</device>
<system>
<resources>
<storages>
<storage id="1" name="My computer\D\temp\masterImg21.img" type="file">
</storage>
</storages>
<network/>
</resources>
</system>
<node id="1" name="imagefile" shut="false" active="true">
<storages>
<storage_ref id="1"/>
</storages>
</node>
</header>
7/7 22:25:09.859 2d34 conf: TelnetListener::listenConnections: Accepted control connection from 172.17.64.3:60044.
7/7 22:25:10.372 1914 IMG: ImageFile_CreateRawFile: File 'D:\temp\partnerImg22.img', size: 12 MB, flags 0x240...
7/7 22:25:10.373 1914 IMG: ImageFile_CreateRawFile: Using SetFileValidData...
7/7 22:25:10.373 1914 IMG: ImageFile_CreateRawFile: Zero out only the first and the last 1MB of the image.
7/7 22:25:10.373 1914 IMG: ImageFile_CreateRawFile: WARNING: This can damage security if the file image is exported directly to untrusted clients!
7/7 22:25:10.391 1914 IMG: ImageFile_CreateRawFile: File 'D:\temp\partnerImg22.img' created. Total elapsed time = 0 sec.
7/7 22:25:10.425 1914 Common: *** sw_common::Sw_Disk_Header::create: (file: D:\temp\partnerImg22.swdsk, cached: no).
7/7 22:25:10.425 1914 Common: *** sw_common::Sw_Disk_Header::create: creation parameters:
- storage path: My computer\D\temp\partnerImg22.img;
- device LUN: 0;
- device size: 12;
- EUI-64: (null);
- mode: none;
- size: 64;
- flags: 0;
- low watermark: 0.
- mode: (null);
- storage: (null);
- size: 0;
- flags: 0;
- low watermark: 0.
7/7 22:25:10.425 1914 Common: *** sw_common::Sw_XML_Storage_Impl::str2type: The "(null)" type is not supported.
7/7 22:25:10.461 1914 Common: sw_common::Sw_Disk_Header::open: (file: D:\temp\partnerImg22.swdsk, readonly: no).
7/7 22:25:10.462 1d1c SCSI: : parameter 'DeviceHeaderPath', value 'My computer\D\temp\partnerImg22.swdsk'.
7/7 22:25:10.462 1d1c SCSI: : parameter 'file', value 'My computer\D\temp\partnerImg22.swdsk'.
7/7 22:25:10.462 1d1c IMG: SscPort_Create: Parsing parameters from control connection:
7/7 22:25:10.462 1d1c IMG: SscPort_Create: Header path parsed to 'D:\temp\partnerImg22.swdsk'.
7/7 22:25:10.462 1d1c IMG: addParameter: Parameter processed (add): DeviceHeaderPathPhysical = "D:\temp\partnerImg22.swdsk"
7/7 22:25:10.462 1d1c IMG: addParameter: Parameter processed (add): file = "My computer\D\temp\partnerImg22.swdsk"
7/7 22:25:10.462 1d1c Common: sw_common::Sw_Disk_Header::open: (file: D:\temp\partnerImg22.swdsk, readonly: no).
7/7 22:25:10.462 1d1c IMG: SscPort_Create: Parsing the Device Header File 'D:\temp\partnerImg22.swdsk':
7/7 22:25:10.463 1d1c IMG: addParameter: Parameter processed (update): file = "My computer\D\temp\partnerImg22.swdsk" -> "My computer\D\temp\partnerImg22.img"
7/7 22:25:10.463 1d1c IMG: addParameter: Parameter processed (add): SerialId = "FF56059158C0D5D3"
7/7 22:25:10.463 1d1c IMG: addParameter: Parameter processed (add): eui64 = "FF56059158C0D5D3"
7/7 22:25:10.463 1d1c IMG: addParameter: Parameter processed (update): SerialId = "FF56059158C0D5D3" -> "FF56059158C0D5D3"
7/7 22:25:10.463 1d1c IMG: addParameter: Parameter processed (update): eui64 = "FF56059158C0D5D3" -> "FF56059158C0D5D3"
7/7 22:25:10.463 1d1c IMG: SscPort_Create: Opening device 'imagefile9', image file 'My computer\D\temp\partnerImg22.img', buffering=0, async=1, readonly=0.
7/7 22:25:10.463 1d1c IMG: *** ImageFile_BuildInquiry: D:\temp\partnerImg22.img: Incompatible logical volume sector size (4096 > 512)!
7/7 22:25:10.464 1d1c IMG: *** SscPort_Create: Create('My computer\D\temp\partnerImg22.img') error (0xc000000d)!
7/7 22:25:10.464 1d1c SCSI: *** iScsiSscDevice::open: Failed to create 'imagefile9' device.
7/7 22:25:10.464 1d1c Srv: iScsiServer::deviceOpen: Device 'imagefile9' - open failed!
7/7 22:25:10.465 1914 conf: ConfCommand::processNew: Device [0x000001E2B07F9E40] 'imagefile9' has been created.
7/7 22:25:10.575 1914 HA: SscPort_ControlRequest: Received create header command
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'CreateHeader', value ''.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'DeviceHeaderPath', value 'My computer\D\temp\partnerImg22_HA.swdsk'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'Type', value 'ImageFile_HA'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'file', value 'imagefile9'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'size', value '12'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'Priority', value '#p0=1;#p1=0'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'nodeType', value '#p0=1;#p1=1'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'PartnerTargetName', value '#p1=iqn.2008-08.com.starwindsoftware:172.17.62.11-targetha21'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'PartnerIP', value '#p1=192.168.39.11:sync:3260:1,172.17.62.11:heartbeat:3260:1'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'IsAutoSynchEnabled', value '1'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'AuthChapLogin', value '#p1=0b'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'AuthChapPassword', value '#p1=0b'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'AuthMChapName', value '#p1=0b'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'AuthMChapSecret', value '#p1=0b'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'AuthChapType', value '#p1=none'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'Offset', value '0'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'CacheMode', value 'none'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'CacheSizeMB', value '64'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'Replicator', value '#p0=0'.
7/7 22:25:10.575 1914 HA: *** HAUtility::create_header: parameter 'plugin', value 'HAImage'.
7/7 22:25:10.575 1914 Common: *** sw_common::Sw_Disk_Header::create: (file: D:\temp\partnerImg22_HA.swdsk, cached: yes).
7/7 22:25:10.576 1914 Common: *** sw_common::Sw_Disk_Header::create: creation parameters:
- plugin name: HAImage;
- storage path: imagefile9;
- device LUN: 0;
- device size: 12;
- EUI-64: (null);
- mode: none;
- size: 64;
- flags: 0;
- low watermark: 0.
- mode: (null);
- storage: (null);
- size: 0;
- flags: 0;
- low watermark: 0.
7/7 22:25:10.576 1914 Common: *** sw_common::Sw_XML_Storage_Impl::str2type: The "(null)" type is not supported.
7/7 22:25:10.576 1914 Common: *** sw_common::storage_type: The specified storage is not supported: .
7/7 22:25:10.576 1914 Common: *** sw_common::Sw_Disk_Header::storage: Either the storage name is empty or its type is invalid.
7/7 22:25:10.681 1914 Common: sw_common::Sw_Disk_Header::open: (file: D:\temp\partnerImg22_HA.swdsk, readonly: no).
7/7 22:25:10.681 1914 Common: *** Browser_ParsePath: Incorrect path supplied: 'imagefile9'!
7/7 22:25:10.681 1914 FileBrowser: *** CFileBrowser::parsePath: Only paths specified in 'imgdir' allowed
7/7 22:25:10.681 1914 Srv: *** iScsiServer::getSscDeviceByStoragePath: Control request failed. Failed to convert virtual path (imagefile9).
7/7 22:25:10.681 1d1c SCSI: : parameter 'DeviceHeaderPath', value 'My computer\D\temp\partnerImg22_HA.swdsk'.
7/7 22:25:10.681 1d1c SCSI: : parameter 'OwnTargetName', value 'iqn.2008-08.com.starwindsoftware:172.17.62.12-partnerha22'.
7/7 22:25:10.681 1d1c SCSI: : parameter 'file', value 'My computer\D\temp\partnerImg22_HA.swdsk'.
7/7 22:25:10.681 1d1c SCSI: : parameter 'serialId', value ''.
7/7 22:25:10.681 1d1c SCSI: : parameter 'asyncmode', value 'yes'.
7/7 22:25:10.681 1d1c SCSI: : parameter 'readonly', value 'no'.
7/7 22:25:10.681 1d1c SCSI: : parameter 'highavailability', value 'yes'.
7/7 22:25:10.681 1d1c SCSI: : parameter 'buffering', value 'no'.
7/7 22:25:10.681 1d1c SCSI: : parameter 'header', value '65536'.
7/7 22:25:10.681 1d1c SCSI: : parameter 'CacheMode', value 'none'.
7/7 22:25:10.681 1d1c SCSI: : parameter 'CacheSizeMB', value '64'.
7/7 22:25:10.681 1d1c SCSI: : parameter 'AluaNodeGroupStates', value '0,0'.
7/7 22:25:10.681 1d1c IMG: SscPort_Create: Parsing parameters from control connection:
7/7 22:25:10.681 1d1c IMG: SscPort_Create: Header path parsed to 'D:\temp\partnerImg22.swdsk'.
7/7 22:25:10.681 1d1c IMG: addParameter: Parameter processed (add): DeviceHeaderPathPhysical = "D:\temp\partnerImg22.swdsk"
7/7 22:25:10.681 1d1c IMG: addParameter: Parameter processed (add): file = "My computer\D\temp\partnerImg22.swdsk"
7/7 22:25:10.681 1d1c Common: sw_common::Sw_Disk_Header::open: (file: D:\temp\partnerImg22.swdsk, readonly: no).
7/7 22:25:10.682 1d1c IMG: SscPort_Create: Parsing the Device Header File 'D:\temp\partnerImg22.swdsk':
7/7 22:25:10.682 1d1c IMG: addParameter: Parameter processed (update): file = "My computer\D\temp\partnerImg22.swdsk" -> "My computer\D\temp\partnerImg22.img"
7/7 22:25:10.682 1d1c IMG: addParameter: Parameter processed (add): SerialId = "FF56059158C0D5D3"
7/7 22:25:10.682 1d1c IMG: addParameter: Parameter processed (add): eui64 = "FF56059158C0D5D3"
7/7 22:25:10.682 1d1c IMG: addParameter: Parameter processed (update): SerialId = "FF56059158C0D5D3" -> "FF56059158C0D5D3"
7/7 22:25:10.682 1d1c IMG: addParameter: Parameter processed (update): eui64 = "FF56059158C0D5D3" -> "FF56059158C0D5D3"
7/7 22:25:10.682 1d1c IMG: SscPort_Create: Opening device 'imagefile9', image file 'My computer\D\temp\partnerImg22.img', buffering=0, async=1, readonly=0.
7/7 22:25:10.682 1d1c IMG: *** ImageFile_BuildInquiry: D:\temp\partnerImg22.img: Incompatible logical volume sector size (4096 > 512)!
7/7 22:25:10.683 1d1c IMG: *** SscPort_Create: Create('My computer\D\temp\partnerImg22.img') error (0xc000000d)!
7/7 22:25:10.683 1d1c SCSI: *** iScsiSscDevice::open: Failed to create 'imagefile9' device.
7/7 22:25:10.683 1d1c Plugin: iScsiPlugin::pluginCallback: Device is not opened by service core!
7/7 22:25:10.683 1d1c Plugin: iScsiPlugin::pluginCallback: Device 'imagefile9' not found or has wrong type!
7/7 22:25:10.683 1d1c HA: *** CHADevice::get_storage_device_interface_by_name: EXITing with failure(failed), error getting storage device interface for device imagefile9, error code 0x57.
7/7 22:25:10.683 1d1c HA: *** SscPort_Create: Getting storage device interface failed, error code 0x57.
7/7 22:25:10.683 1d1c HA: *** CHADevice::release_storage_device_interface: Error releasing storage device interface, error code 0x57.
7/7 22:25:10.683 1d1c SCSI: *** iScsiSscDevice::open: Failed to create 'HAImage6' device.
7/7 22:25:10.683 1d1c Srv: iScsiServer::deviceOpen: Device 'HAImage6' - open failed!
7/7 22:25:10.683 1914 conf: ConfCommand::processNew: Device [0x000001E2B0BE3CC0] 'HAImage6' has been created.
7/7 22:25:10.729 1d1c Srv: iScsiServer::addTargetCallback: Creating target 'iqn.2008-08.com.starwindsoftware:172.17.62.12-partnerha22', type 0, device list 'HAImage6'...
7/7 22:25:10.730 1d1c SCSI: : parameter 'DeviceHeaderPath', value 'My computer\D\temp\partnerImg22_HA.swdsk'.
7/7 22:25:10.730 1d1c SCSI: : parameter 'OwnTargetName', value 'iqn.2008-08.com.starwindsoftware:172.17.62.12-partnerha22'.
7/7 22:25:10.730 1d1c SCSI: : parameter 'file', value 'My computer\D\temp\partnerImg22_HA.swdsk'.
7/7 22:25:10.730 1d1c SCSI: : parameter 'serialId', value ''.
7/7 22:25:10.730 1d1c SCSI: : parameter 'asyncmode', value 'yes'.
7/7 22:25:10.730 1d1c SCSI: : parameter 'readonly', value 'no'.
7/7 22:25:10.730 1d1c SCSI: : parameter 'highavailability', value 'yes'.
7/7 22:25:10.730 1d1c SCSI: : parameter 'buffering', value 'no'.
7/7 22:25:10.730 1d1c SCSI: : parameter 'header', value '65536'.
7/7 22:25:10.730 1d1c SCSI: : parameter 'CacheMode', value 'none'.
7/7 22:25:10.730 1d1c SCSI: : parameter 'CacheSizeMB', value '64'.
7/7 22:25:10.730 1d1c SCSI: : parameter 'AluaNodeGroupStates', value '0,0'.
7/7 22:25:10.730 1d1c SCSI: : parameter '#_TargetName_#', value 'iqn.2008-08.com.starwindsoftware:172.17.62.12-partnerha22'.
7/7 22:25:10.730 1d1c IMG: SscPort_Create: Parsing parameters from control connection:
7/7 22:25:10.730 1d1c IMG: SscPort_Create: Header path parsed to 'D:\temp\partnerImg22.swdsk'.
7/7 22:25:10.730 1d1c IMG: addParameter: Parameter processed (add): DeviceHeaderPathPhysical = "D:\temp\partnerImg22.swdsk"
7/7 22:25:10.730 1d1c IMG: addParameter: Parameter processed (add): file = "My computer\D\temp\partnerImg22.swdsk"
7/7 22:25:10.730 1d1c Common: sw_common::Sw_Disk_Header::open: (file: D:\temp\partnerImg22.swdsk, readonly: no).
7/7 22:25:10.730 1d1c IMG: SscPort_Create: Parsing the Device Header File 'D:\temp\partnerImg22.swdsk':
7/7 22:25:10.730 1d1c IMG: addParameter: Parameter processed (update): file = "My computer\D\temp\partnerImg22.swdsk" -> "My computer\D\temp\partnerImg22.img"
7/7 22:25:10.730 1d1c IMG: addParameter: Parameter processed (add): SerialId = "FF56059158C0D5D3"
7/7 22:25:10.731 1d1c IMG: addParameter: Parameter processed (add): eui64 = "FF56059158C0D5D3"
7/7 22:25:10.731 1d1c IMG: addParameter: Parameter processed (update): SerialId = "FF56059158C0D5D3" -> "FF56059158C0D5D3"
7/7 22:25:10.731 1d1c IMG: addParameter: Parameter processed (update): eui64 = "FF56059158C0D5D3" -> "FF56059158C0D5D3"
7/7 22:25:10.731 1d1c IMG: SscPort_Create: Opening device 'imagefile9', image file 'My computer\D\temp\partnerImg22.img', buffering=0, async=1, readonly=0.
7/7 22:25:10.731 1d1c IMG: *** ImageFile_BuildInquiry: D:\temp\partnerImg22.img: Incompatible logical volume sector size (4096 > 512)!
7/7 22:25:10.731 1d1c IMG: *** SscPort_Create: Create('My computer\D\temp\partnerImg22.img') error (0xc000000d)!
7/7 22:25:10.731 1d1c SCSI: *** iScsiSscDevice::open: Failed to create 'imagefile9' device.
7/7 22:25:10.731 1d1c Plugin: iScsiPlugin::pluginCallback: Device is not opened by service core!
7/7 22:25:10.731 1d1c Plugin: iScsiPlugin::pluginCallback: Device 'imagefile9' not found or has wrong type!
7/7 22:25:10.731 1d1c HA: *** CHADevice::get_storage_device_interface_by_name: EXITing with failure(failed), error getting storage device interface for device imagefile9, error code 0x57.
7/7 22:25:10.731 1d1c HA: *** SscPort_Create: Getting storage device interface failed, error code 0x57.
7/7 22:25:10.731 1d1c HA: *** CHADevice::release_storage_device_interface: Error releasing storage device interface, error code 0x57.
7/7 22:25:10.731 1d1c SCSI: *** iScsiSscDevice::open: Failed to create 'HAImage6' device.
7/7 22:25:10.731 1d1c Srv: iScsiServer::deviceOpen: Device 'HAImage6' - open failed!
7/7 22:25:10.731 1d1c Tgt: iScsiTarget::attachDevice: : * cannot open the device 'HAImage6'. It is not active.
7/7 22:25:10.731 1d1c IMG: SscPort_Create: Parsing parameters from control connection:
7/7 22:25:10.731 1d1c IMG: SscPort_Create: Header path parsed to 'D:\temp\partnerImg22.swdsk'.
7/7 22:25:10.731 1d1c IMG: addParameter: Parameter processed (add): DeviceHeaderPathPhysical = "D:\temp\partnerImg22.swdsk"
7/7 22:25:10.732 1d1c IMG: addParameter: Parameter processed (add): file = "My computer\D\temp\partnerImg22.swdsk"
7/7 22:25:10.732 1d1c Common: sw_common::Sw_Disk_Header::open: (file: D:\temp\partnerImg22.swdsk, readonly: no).
7/7 22:25:10.732 1d1c IMG: SscPort_Create: Parsing the Device Header File 'D:\temp\partnerImg22.swdsk':
7/7 22:25:10.732 1d1c IMG: addParameter: Parameter processed (update): file = "My computer\D\temp\partnerImg22.swdsk" -> "My computer\D\temp\partnerImg22.img"
7/7 22:25:10.732 1d1c IMG: addParameter: Parameter processed (add): SerialId = "FF56059158C0D5D3"
7/7 22:25:10.732 1d1c IMG: addParameter: Parameter processed (add): eui64 = "FF56059158C0D5D3"
7/7 22:25:10.732 1d1c IMG: addParameter: Parameter processed (update): SerialId = "FF56059158C0D5D3" -> "FF56059158C0D5D3"
7/7 22:25:10.732 1d1c IMG: addParameter: Parameter processed (update): eui64 = "FF56059158C0D5D3" -> "FF56059158C0D5D3"
7/7 22:25:10.732 1d1c IMG: SscPort_Create: Opening device 'imagefile9', image file 'My computer\D\temp\partnerImg22.img', buffering=0, async=1, readonly=0.
7/7 22:25:10.732 1d1c IMG: *** ImageFile_BuildInquiry: D:\temp\partnerImg22.img: Incompatible logical volume sector size (4096 > 512)!
7/7 22:25:10.733 1d1c IMG: *** SscPort_Create: Create('My computer\D\temp\partnerImg22.img') error (0xc000000d)!
7/7 22:25:10.733 1d1c SCSI: *** iScsiSscDevice::open: Failed to create 'imagefile9' device.
<storages>
<inquiry>
<serial_id>FF56059158C0D5D3</serial_id>
<eui_64>FF56059158C0D5D3</eui_64>
</inquiry>
<geometry>
<sector size="512" psize="4096"/>
<cylinder tracks="32" count="48"/>
</geometry>
</storage>
</storages>
</device>
<system>
<resources>
<storages>
<storage id="1" name="My computer\D\temp\partnerImg22.img" type="file">
</storage>
</storages>
<network/>
</resources>
</system>
<storages>
</storages>
</node>
</header>
Is there any alternative way to create HA devices via PowerShell? Can we create the image devices on each node and then bind them together by creating the HA devices? I have also noticed a new Add-HADevice in the PowerShell module but there is no documentation on it at all.
7/7 22:00:44.930 30b8 Srv: StarWind Virtual SAN v8.0.0 (Build 12166, [SwSAN], Win64)
7/7 22:00:44.930 30b8 Srv: Built May 7 2018 17:45:06
7/7 22:00:44.937 30b8 Srv: Windows Server 2016 Standard Edition (v10.0 Build 14393)
7/7 22:00:44.937 30b8 Srv: Processor packages/cores/logical: 2/16/32
