Create a HA LSFS disk from powershell but with deduplication disabled
Locked
Chill0309
Sat Jun 09, 2018 10:59 am
I'm trying to create a HA LSFS disk from powershell but with deduplication disabled. Following the powershell samples I can do everything but.
Option 1: Creates a HA disk with thick provisioning
# Define nodes etc first...
Option 2: Creates a HA disk with LSFS and deduplication ON
$firstNode.storageType = [StarWindFileType]::STARWIND_DD_FILE
$secondNode.storageType = [StarWindFileType]::STARWIND_DD_FILE
Option 3: Creates a single LSFS disk with deduplication OFF
$device = Add-DDDevice -server $server -path "My Computer\C\Starwind" -fileName $fileName -storageSize 128 -sectorSize 512 -CacheMode "wb" -CacheSize 128 -DeduplicationEnabled $false
Option 4: Creates a HA LSFS disk with deduplication OFF
Any help appreciated :)
Oleg(staff)
Tue Jun 12, 2018 3:33 pm
Unfortunately, the possibility of creation LSFS disk with deduplication OFF is not available yet via PowerShell.
carinamon
Mon Jun 19, 2023 3:34 am
This command creates a mirrored virtual disk using the specified physical disk, initializes it, creates a partition using maximum available size, formats the volume as NTFS with a specified label, and disables deduplication on the volume.
Tue Feb 27, 2024 1:20 pm
LSFS is considered EoL. We're brining another in-line deduplication engine at this point.
== thread closed ==
Locked
