Here is the log of us trying to connect to StarWind.
10/5 18:26:10 ec Srv: StarWind iSCSI Target v2.6.4 (Build 20050908, Win32)
10/5 18:26:10 ec Srv: *** TRIAL VERSION *** [ expires in 14 day(s) ]
10/5 18:26:10 ec Srv: Please contact Rocket Division Software at <
info@rocketdivision.com> for more details.
10/5 18:26:10 ec Srv: Unlimited number of client hosts allowed.
10/5 18:26:10 ec Srv: Config file: 'C:\Program Files\Rocket Division Software\StarWind\starwind.conf'
10/5 18:26:10 ec conf: 'LogLevel' = '1'
10/5 18:26:10 ec conf: 'LogMask' = '0x8fffffff'
10/5 18:26:10 ec conf: 'Port' = '3260'
10/5 18:26:10 ec conf: 'Interface' = '0.0.0.0'
10/5 18:26:10 ec conf: 'DefTargetName' = 'iqn.2003-06.com.rocketdivision.starwind:$(host).$(symid)'
10/5 18:26:10 ec conf: 'Login' = 'test'
10/5 18:26:10 ec conf: 'Password' = '##CY9rzUYh03PK3k6DJie09g=='
10/5 18:26:10 ec conf: 'Echo' = 'no'
10/5 18:26:10 ec conf: 'MinBufferSize' = '65536'
10/5 18:26:10 ec conf: 'AlignmentMask' = '0x0000'
10/5 18:26:10 ec conf: 'MaxPendingRequests' = '64'
10/5 18:26:10 ec conf: Variable 'LogLevel' is set to '1'.
10/5 18:26:10 ec conf: Variable 'LogMask' is set to '0x8fffffff'.
10/5 18:26:10 ec conf: Variable 'Port' is set to '3260'.
10/5 18:26:10 ec conf: Variable 'Interface' is set to '0.0.0.0'.
10/5 18:26:10 ec conf: Variable 'DefTargetName' is set to 'iqn.2003-06.com.rocketdivision.starwind:$(host).$(symid)'.
10/5 18:26:10 ec conf: Variable 'Login' is set to 'test'.
10/5 18:26:10 ec conf: Variable 'Password' is set to '##CY9rzUYh03PK3k6DJie09g=='.
10/5 18:26:10 ec conf: Variable 'Echo' is set to 'no'.
10/5 18:26:10 ec conf: Variable 'MinBufferSize' is set to '65536'.
10/5 18:26:10 ec conf: Variable 'AlignmentMask' is set to '0x0000'.
10/5 18:26:10 ec conf: Variable 'MaxPendingRequests' is set to '64'.
10/5 18:26:10 ec conf: 'RamDisk.dll' loaded successfully.
10/5 18:26:10 ec IMAGE: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Alias: 'My Computer'
Extensions: 'img,dat'
10/5 18:26:10 ec conf: 'ImageFile.dll' loaded successfully.
10/5 18:26:10 ec VDVD: *SscPort_Init:
Dirname: '*'
Rights: 0x18
Extensions: 'mds,iso'
10/5 18:26:10 ec conf: 'VirtualDvd.dll' loaded successfully.
10/5 18:26:10 ec IBV: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Extensions: 'ibv'
Dirname: '*'
Rights: 0x18
Alias: 'Readonly ImageFiles'
10/5 18:26:10 ec conf: 'IBVolume.dll' loaded successfully.
10/5 18:26:10 ec IMAGE: *ERROR* ImageFile_Create: '\\.\X:': cannot open the image file (2).
10/5 18:26:10 ec IMAGE: *ERROR* SscPort_Create: Create('\\.\X:') error (0xc0000001)!
10/5 18:26:10 ec SCSI: Failed to create 'ImageFile1' device.
10/5 18:26:10 ec S: *ERROR* cannot open the device 'ImageFile1'.
10/5 18:26:10 ec Srv: * Device test failed for 'ImageFile1'.
10/5 18:26:10 ec conf: Device test failed for 'ImageFile1'.
10/5 18:26:10 ec S: the device 'RamDrive0' is opened successfully.
10/5 18:26:10 ec S: Assigned target name: 'iqn.2003-06.com.rocketdivision.starwind:iscsi2.vroooom.local.ramdisk.ramdrive0', SymId: 'RAMdisk.RamDrive0'.
10/5 18:26:10 ec S: parameter 'size', value '16'.
10/5 18:26:10 ec S: parameter 'format', value 'yes'.
10/5 18:26:10 ec S: clustered 0.
10/5 18:26:10 ec S: iqn.2003-06.com.rocketdivision.starwind:iscsi2.vroooom.local.ramdisk.ramdrive0: 1 session(s) allowed.
10/5 18:26:10 ec conf: Target [0x93ad0] has been created. Device 'RamDrive0' is accesible as target 'iqn.2003-06.com.rocketdivision.starwind:iscsi2.vroooom.local.ramdisk.ramdrive0'.
10/5 18:26:10 ec S: the device '\\.\PhysicalDrive1' is opened successfully.
10/5 18:26:10 ec S: Assigned target name: 'iqn.2003-06.com.rocketdivision.starwind:iscsi2.vroooom.local.spti:disk.physicaldrive1', SymId: 'SPTI:Disk.PhysicalDrive1'.
10/5 18:26:10 ec S: parameter 'readonly', value 'no'.
10/5 18:26:10 ec S: sessions 1.
10/5 18:26:10 ec S: iqn.2003-06.com.rocketdivision.starwind:iscsi2.vroooom.local.spti:disk.physicaldrive1: 1 session(s) allowed.
10/5 18:26:10 ec conf: Target [0x90950] has been created. Device '\\.\PhysicalDrive1' is accesible as target 'iqn.2003-06.com.rocketdivision.starwind:iscsi2.vroooom.local.spti:disk.physicaldrive1'.
10/5 18:26:10 ec Srv: Refreshing device list (complete)...
10/5 18:26:12 ec Srv: Found SPTI device '\\.\D:': ' TEAC CD-540E 1.0A'
10/5 18:26:12 ec SPTI: '\\.\Z:': Test failed, the device cannot execute SCSI command. Status 0, SCSI status 0x0.
10/5 18:26:12 ec Srv: Found SPTI device '\\.\PhysicalDrive0': ' WDC WD800JD-00LSA0 06.01D06'
10/5 18:26:13 ec IMAGE: *ERROR* ImageFile_Create: '\\.\C:': cannot open the image file (32).
10/5 18:26:13 ec IMAGE: *ERROR* SscPort_Create: Create('\\.\C:') error (0xc0000001)!
10/5 18:26:13 ec SCSI: Failed to create 'ImageFile1' device.
10/5 18:26:13 ec Plugin: Test for device 'ImageFile1' failed.
10/5 18:26:14 ec Plugin: A new device 'ImageFile0' found.
10/5 18:26:14 ec Srv: Binding to 0.0.0.0:3260 ...
10/5 18:26:14 54c conf: Waiting for a control connection at port 3261 ...
10/5 18:26:14 ec Srv: Waiting for a connection at port 0.0.0.0:3260 ...
Chris
