Hi
I'm having a couple of problems with starwind. When I create a larger LSFS drive with de-duplication, windows hangs on formatting it. I'm not sure what size where it stops working. I can format a 500mb drive without any problems. 2TB and over hangs. Thick provisioned and LSFS without de-duplication works fine. I can get around the problem by creating a 200mb partition and then extend it to the full drive.
The second problem I have is when I try to Add to Cluster Shared Volumes it gave me an error 0x800713b8 "The cluster request is not valid for this object"
This is a fresh windows install. windows 2016 server standard and starwind are the only applications installed. This occurs with all types of starwind drives. Thick provisioned and LSFS with/without de-duplication
any help is greatly appreciated.
