Create New Device Powershell
chrisguk
Thu Nov 30, 2017 4:08 pm
Hi I am trying to create new devices with the script below but I get getting the errors:
Exception Exception calling "CreateDevice" with "4" argument(s): "Error:
200 Failed: operation cannot be completed.. "
200 Failed: There is not enough space on the disk.. "
	Import-Module StarWindX
$storage = 'FS1'
$storage2 = 'FS2'
	try
		$server = New-SWServer -host $storage -port 3261 -user root -password starwind
		$server.Connect()
		$firstNode = new-Object Node
		$firstNode.ImagePath = "My computer\E"
		$firstNode.ImageName = "CSV1"
		$firstNode.Size = 20000
		$firstNode.TargetAlias = "csv1"
		$firstNode.AutoSynch = $true
		$firstNode.SyncInterface = "#p2=10.32.10.10:3260"
		$firstNode.HBInterface = "#p2=10.32.35.80:3260"
		$firstNode.CacheSize = 128
		$firstNode.CacheMode = "wb"
		$firstNode.PoolName = "SW"
		$secondNode = new-Object Node
		$secondNode.HostName = $storage2
		$secondNode.HostPort = "3261"
		$secondNode.Login = "root"
		$secondNode.ImagePath = "My computer\E"
		$secondNode.ImageName = "CSV1"
		$secondNode.Size = 20000
		$secondNode.TargetAlias = "csv1"
		$secondNode.AutoSynch = $true
		$secondNode.SyncInterface = "#p1=10.32.10.20:3260"
		$secondNode.HBInterface = "#p1=10.32.35.81:3260"
		Start-Sleep -m 1000
		$syncState = $device.GetPropertyValue("ha_synch_status")
		while ($syncState -ne "1")
			$device.Refresh()
			Start-Sleep -m 500
	catch
		Write-Host "Exception $($_.Exception.Message)" -foreground red
	try
		$server.Connect()
		$firstNode.ImageName = "CSV2"
		$firstNode.TargetAlias = "csv2"
		$secondNode.ImageName = "CSV2"
		$secondNode.TargetAlias = "csv2"
		Start-Sleep -m 1000
			$device.Refresh()
			Start-Sleep -m 500
	catch
	try
		$server.Connect()
		$firstNode.ImageName = "witness"
		$firstNode.Size = 10000
		$firstNode.TargetAlias = "witness"
		$firstNode.SectorSize = 512
		$firstNode.SerialID = ""
		$secondNode.ImageName = "witness"
		$secondNode.Size = 10000
		$secondNode.TargetAlias = "witness"
		$secondNode.SyncInterface = "#p1=10.32.10.10:3260"
		Start-Sleep -m 1000
			$device.Refresh()
			Start-Sleep -m 500
	catch
	$server.Disconnect()
Can you please offer some advice?
Thu Nov 30, 2017 5:11 pm
In your case, the interfaces stated in the italics block are the ones on node 1, are they not? The matter is that if there is the key "p2" before the interface, the IP address of the partner node should follow, but not the local node IP. If it is "p1", then node 1 interfaces are there.
Check that the IPs are from partner nodes - it should be:
$firstNode.SyncInterface = "#p2=Sync_IP_on_node_2"
$firstNode.HBInterface = "#p2=iSCSI_IP_on_node_2"
Feel free to amend the script accordingly (for all devices and both nodes) and let me know the outcome.
chrisguk
Fri Dec 01, 2017 10:52 am
So I made the change and I still get this error - Exception Exception calling "CreateDevice" with "4" argument(s): "Error:
try
		$server.Connect()
		$firstNode.SyncInterface = "#p2=10.32.10.20:3260"
		$firstNode.HBInterface = "#p2=10.32.35.81:3260"
		$secondNode.HBInterface = "#p1=10.32.35.80:3260"
		Start-Sleep -m 1000
			$device.Refresh()
			Start-Sleep -m 500
	catch
Fri Dec 01, 2017 11:22 am
First of all, your latest script is missing variables declaration at the very top:
$storage = 'FS1'
$storage2 = 'FS2'
This may be one of the reasons.
Next, try connecting not to "$storage", but to 127.0.0.1 in case you execute the script on one of the HA nodes.
$server.Connect()
chrisguk
Fri Dec 01, 2017 5:25 pm
okay now I get this error. By the way it creates the first images on FS2 not FS1:
104 Target name 'iqn.2008-08.com.starwindsoftware:FS2-csvone' is invalid according to RFC 3722!. "
104 Target name 'iqn.2008-08.com.starwindsoftware:FS2-csvtwo' is invalid according to RFC 3722!. "
104 Target name 'iqn.2008-08.com.starwindsoftware:FS2-witness' is invalid according to RFC 3722!. "
Updated script:
	$NODE1IPISCSI = "10.32.35.82"
$NODE2IPISCSI = "10.32.35.83"
$FS1SYNCIP = "10.32.10.10"
$FS2SYNCIP = "10.32.10.20"
$FS1HBIP = "10.32.35.80"
$FS2HBIP = "10.32.35.81"
$servers = 'winnode1', 'winnode2'
$storage = 'FS1'
$storage2 = 'FS2'
	try
		$server.Connect()
		$firstNode.ImageName = "csvone"
		$firstNode.TargetAlias = "csvone"
		$secondNode.ImageName = "csvone"
		$secondNode.TargetAlias = "csvone"
		Start-Sleep -m 1000
			$device.Refresh()
			Start-Sleep -m 500
	catch
	try
		$server.Connect()
		$firstNode.ImageName = "csvtwo"
		$firstNode.TargetAlias = "csvtwo"
		$secondNode.ImageName = "csvtwo"
		$secondNode.TargetAlias = "csvtwo"
		Start-Sleep -m 1000
			$device.Refresh()
			Start-Sleep -m 500
	catch
	try
		$server.Connect()
		$secondNode.Size = 8192
		Start-Sleep -m 1000
			$device.Refresh()
			Start-Sleep -m 500
	catch
Michael (staff)
Fri Dec 01, 2017 6:12 pm
You shouldn't use capital letters in the target name. They are present in $storage and $storage2 .
chrisguk
Sat Dec 02, 2017 11:08 am
ok now it works!
What is the command to check the sync status of any image/device in powershell?
Oleg(staff)
Mon Dec 04, 2017 3:48 pm
Hi chrisguk,
You can consider GetHASyncState.ps1 script to get devices state.
