HA Devices not syncing
jortie
Wed Sep 27, 2017 12:45 am
I setup Starwind Free with two nodes. This worked fine untill I restarted one node. I noticed that DNS wasn`t working anymore so both nodes couldnt reach eachother.
All VM`s automatically live migrated to node 2. Once I restarted node 1, all vm`s went into saved - critical state and all csv`s including the witness went offline.
After I fixed DNS and disabled all firewall`s, the witness disk came back online. My two data volumes didn`t came back online. I dont see any network activity on the replication network interface.
This is my log from node 2
9/27 0:57:18.483 9a8 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:s002.clr001.syso.local', accepted 'iqn.1991-05.com.microsoft:s002.clr001.syso.local'
9/27 0:57:18.483 558 Srv: WSARecv() failed with error 10054 (0x2746)!
9/27 0:57:18.483 554 C[4f], IN_LOGIN: T7.
9/27 0:57:18.483 182c Tgt: iqn.2008-08.com.starwindsoftware:192.168.0.103-witness: can't register session. The device 'HAImage3' is not ready.
9/27 0:57:18.483 9a8 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
9/27 0:57:18.483 558 C[4f], IN_LOGIN: recvData returned 10054 (0x2746)!
9/27 0:57:18.483 9a8 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:s002-coldstorage', accepted 'iqn.2008-08.com.starwindsoftware:s002-coldstorage'
9/27 0:57:18.483 182c T[50,1]: *ERROR* Login request: device open failed.
9/27 0:57:18.483 9a8 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
9/27 0:57:18.483 9a8 HA: CHADevice::register_session: Client initiator iqn.1991-05.com.microsoft:s002.clr001.syso.local is trying to register a session within the 'iqn.2008-08.com.starwindsoftware:s002-coldstorage' target... (sessId = 0x51, initiatorNameIsid = iqn.1991-05.com.microsoft:s002.clr001.syso.local,400001370001)
9/27 0:57:18.483 9a8 HA: CHADevice::register_session: Unable to register the new client session. The node is not active!
9/27 0:57:18.483 54c C[50], IN_LOGIN: Event - LOGIN_REJECT.
9/27 0:57:18.483 9a8 HA: CHADevice::register_session: Return code 21.
9/27 0:57:18.483 182c Srv: WSARecv() failed with error 10054 (0x2746)!
9/27 0:57:18.483 54c C[50], IN_LOGIN: T7.
9/27 0:57:18.483 182c C[50], IN_LOGIN: recvData returned 10054 (0x2746)!
9/27 0:57:18.483 9a8 Tgt: iqn.2008-08.com.starwindsoftware:s002-coldstorage: can't register session. The device 'HAImage5' is not ready.
9/27 0:57:18.483 56c S[4f]: ~Session
9/27 0:57:18.483 9a8 T[51,1]: *ERROR* Login request: device open failed.
9/27 0:57:18.483 1830 C[51], IN_LOGIN: Event - LOGIN_REJECT.
9/27 0:57:18.483 9a8 Srv: WSARecv() failed with error 10054 (0x2746)!
9/27 0:57:18.483 19e0 S[50]: ~Session
9/27 0:57:18.483 1830 C[51], IN_LOGIN: T7.
9/27 0:57:18.483 9a8 C[51], IN_LOGIN: recvData returned 10054 (0x2746)!
9/27 0:57:18.483 940 S[51]: ~Session
How should I go about solving this? I only have powershell access btw
Sergey (staff)
Thu Sep 28, 2017 10:17 am
Hello, jortie. Could you please answer few more questions to clarify the issue:
Can you ping the partner node through Synchronization channel?
Check the status of StarWind devices with GetHASyncState.ps1 script, by default located in C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell
Do you use direct cross-link switchless connection between nodes (synchronization network interface)?
Do your servers get IP addresses over DHCP or are IP addresses set statically?
