Issue Creating HAImage
dandickson
Mon May 22, 2017 2:43 pm
I'm leaving the original post just in case someone else makes the same mistake as I:
Node.SyncInterface and Node.HBInterface refer to the opposing system, not the interface on the system you are referencing as that node.
I'm trying to create a HAImage using only the powershell scripts, in my examples below, 192.168.69.15/10.255.255.15 is node 1 and 192.168.69.18/10.255.255.18 is node 2:
#Import-Module StarWindX
try
    $server = New-SWServer -host 192.168.69.15 -port 3261 -user root -password starwind
    $server.Connect()
    $firstNode = new-Object Node
    $firstNode.ImagePath = "My computer\D\Storage"
    $firstNode.ImageName = "quorum"
    $firstNode.Size = 10240
    $firstNode.TargetAlias = "quorum"
    $firstNode.AutoSynch = $true
    $firstNode.SyncInterface = "#p2=10.255.255.15:3260"
    $firstNode.HBInterface = "#p2=192.168.69.15:3260"
    $firstNode.CacheSize = 64
    $firstNode.CacheMode = "wb"
    $firstNode.PoolName = "quorum"
    $firstNode.SectorSize = 512
	# 'SerialID' should be between 16 and 31 symbols. If it not specified StarWind Service will generate it.
	# Note: Second node always has the same serial ID. You do not need to specify it for second node
	$firstNode.SerialID = "050176c0b535403ba3ce02102e33eab"
    $secondNode = new-Object Node
    $secondNode.HostName = "192.168.69.18"
    $secondNode.HostPort = "3261"
    $secondNode.Login = "root"
    $secondNode.ImagePath = "My computer\D\Storage"
    $secondNode.ImageName = "quorum"
    $secondNode.Size = 256
    $secondNode.TargetAlias = "quorum"
    $secondNode.AutoSynch = $true
    $secondNode.SyncInterface = "#p1=10.255.255.18:3260"
    $secondNode.HBInterface = "#p1=192.168.69.18:3260"
    $syncState = $device.GetPropertyValue("ha_synch_status")
    while ($syncState -ne "1")
        # Refresh device info
        $device.Refresh()
        Start-Sleep -m 2000
catch
    Write-Host "Exception $($_.Exception.Message)" -foreground red
$server.Disconnect()
Running the above results in the following:
Exception Exception calling "CreateDevice" with "4" argument(s): "Error:
200 Synchronization cannot be started because the nodes are not ready! Try to synchronize the nodes manually.
Pending. "
Running an enumDeviceTargets on Node 1 shows the device being created:
Targets:
Alias       : quorum
IsClustered : True
Devices     : System.__ComObject
Permissions : System.__ComObject
Type        :
Devices:
DeviceType              : HA Image
DeviceId                : 0x000000C4A3786340
File                    : My computer\D\Storage\quorum_HA.swdsk
TargetName              : iqn.2008-08.com.starwindsoftware:192.168.69.15-quorum
TargetId                : 0x000000C4A94CF940
CacheMode               : wb
CacheSize               : 64
CacheBlockExpiryPeriod  : 5000
Exists                  : True
DeviceLUN               : 0
IsSnapshotsSupported    : False
Snapshots               :
SectorSize              : 512
Partners                : System.__ComObject
SynchronizationChannels : System.__ComObject
HeartbeatChannels       : System.__ComObject
SyncStatus              : 3
DeviceType             : Image file
DeviceId               : 0x000000C4A46428C0
File                   : My computer\D\Storage\quorum.img
TargetName             : empty
TargetId               : empty
CacheMode              : wb
CacheSize              : 64
Exists                 : True
DeviceLUN              :
Snapshots              :
SectorSize             : 512
And on node 2:
Targets:
Alias       : quorum
IsClustered : True
Type        :
Devices:
CacheMode               : wb
CacheSize               : 64
Exists                  : True
DeviceLUN               : 0
Snapshots               :
SectorSize              : 512
SyncStatus              : 3
TargetName             : empty
TargetId               : empty
CacheMode              : wb
CacheSize              : 64
Exists                 : True
DeviceLUN              :
Snapshots              :
SectorSize             : 512
However running the GetHASyncState using the following:
# This following example shows how to get synchronization status of specified HA device and
# if there is a need run synchronization
try
    # connect to the server
    $server.Connect()
    # Try to find specified device
    $deviceName = "HAImage1"
    $partnerTargetName = "iqn.2008-08.com.starwindsoftware:192.168.69.18-quorum"
    $deviceFound = $false
    foreach($device in $server.devices)
        if ($device.name -eq $deviceName)
            Write-Host "$($deviceName)" -foreground yellow
            Write-Host ""
            $deviceFound = $true
                # Device not synchronized. Maybe it waiting for autosynchronization ?
                $waitForAutoSync = $device.GetPropertyValue("ha_wait_on_autosynch")
                if ( $waitForAutoSync -eq "1" )
                    Write-Host "Waiting for autosynchronization..." -foreground yellow
                else
                    if ( $syncState -eq "2" )
                        # Device is synchronizing. Get synchronization percent and show it
                    if ( $syncState -eq "3" )
                        # Device not synchronized. Synchronize current node from partner
                        Write-Host "Device not synchronized. Synchronize current node from partner '$($partnerTargetName)'" -foreground yellow
                        $params = new-object -ComObject StarWindX.Parameters
                        $params.AppendParam("deviceID",$device.DeviceId)
                        $params.AppendParam("partnetTargetName",$partnerTargetName)
                        $server.ExecuteCommand( 0, "restoreHAPartnerNode", $params)
                        # If you want to synchronize partners from current node you can comment out code above and uncomment section below
                        # Device not synchronized. Mark current node as 'Synchronized'.
                        # WARNING, Command changes Device Status to "Synchronized" without Data Synchronization with HA (High Availability) Partner,
                        # Device will start processing Client Requests immediately and will be used as Data Synchronization Source for Partner Device.
                        Write-Host "Device not synchronized. Mark current node as 'Synchronized'. " -foreground yellow
                        $server.ExecuteCommand( 0, "restoreCurrentHANode", $params)
                        Start-Sleep -m 5000
                $device.Refresh()
                Start-Sleep -m 1000
            Write-Host "Synchronization Status: Synchronized" -foreground yellow
            break;
    if ( $deviceFound -ne $true )
        Write-Host "$($deviceName) not found" -foreground red
catch
$server.Disconnect( )
Returns the error:
HAImage1
Device not synchronized. Synchronize current node from partner 'iqn.2008-08.com.starwindsoftware:192.168.69.18-quorum'
Exception Exception calling "ExecuteCommand" with "3" argument(s): "Error:
200 Failed: connection with partner node is invalid.. "
I'm a little stumped, i'm sure it's something simple but i'm just not seeing it.
Thanks[/size][/i]
Ivan (staff)
Wed May 24, 2017 5:09 pm
Hello dandockson,
Thanks for your interest in StarWind solution
Yes, as far as you can see in script examples #p1 is first node interfaces and #p2 is the second node interfaces
