I am using 2 identical servers spec'd as below:
- Dell PowerEdge T610
- Dual Xeon E5600 series CPUs
- 72GB RAM
- 4x1TB RAID 10 (OS / Data on same array, OBR10)
- 4x 1GB NIC (2x onboard, 2x PCIe on single card)
What I would like to do is maximize my iSCSI layering so if NODE1's SAN layer goes down for some reason and the NODE remains active from a cluster standpoint, when it fails over it will utilize multiple NIC's for iSCSI.... IE:
- 127.0.0.1 used for primary
- x.x.x.1, x.x.x.2, x.x.x3 for failover w/round robin type mentaility
Not even sure this is possible. Running about 12 VMs between the two systems including Exchange, DC, SQL...
