I have just watched this Starwind Youtube video:
https://www.youtube.com/watch?v=C4fCeDrsSqc
(Accelerate your performance by deploying iSER to your StarWind infrastructure)
I am keen on replacing my 1Gb NICs in the SAN/hosts with 40Gb/s Infiniband cards but I have a few questions first:
1) Does Starwind Virtual SAN 8.0.9996.0 support iSER?
2) In the video it was mentioned that Mellanox cards are the only ones supported, which Mellanox cards are supported with Starwind that can use iSER and will work with ESXi 6.5?
3) The video also mentioned that ESXi 6.5 is the only version of ESXi that supports iSER so I'll be upgrading to that at the end of the month. So if I have ESXi 6.5, the correct Mellanox Infiniband cards and the correct version of Starwind Virtual SAN can I make use of iSER/RDMA for my storage between the ESXi hosts and SAN?
4) Can I use direct connect connections between the SAN and ESXi servers? (ie: no Infiniband switch)
5) Currently I use Veeam for backups and use "Direct SAN" for backups/restores which gives great performance but can I continue using this with an Infiniband/iSER setup?
Many thanks!
