Van Rue
Mon Sep 26, 2016 8:36 pm
I had set up my Starwind VSAN in 2 node storage cluster per instructions, and it (seems to be) working fine. However in set up I was thrown a tiny bit because Microsoft Fail Over Cluster Manager wanted its own CSV network connection, and this wasn't mentioned in the directions. I added 2 direct connect Cat 6 cables for a 2 node cluster just to be sure. Is a dedicated connection needed? Or can I use the main TCIP Network? or is all the traffic routed over the Starwind iSCSI connections? and this will sit there useless?
Van Rue
Thu Oct 06, 2016 6:03 pm
I am more specifically looking at data volume requirements of MS CSV communitcations. I had 2 extra 1gb ports so I teamed them for Cluster communications. But I don't know if this is overkill, or I can just use the main LAN. How much data goes along this path in Starwind scenario? Not much I assume.
Michael (staff)
Mon Oct 10, 2016 4:53 pm
Basically, StarWind using only two types of networks for communication: Synchronization and Heartbeat. In case if you are using the Team above for the StarWind Heartbeat network, it will consume several MB per day, so you are correct, not much
