Creating new device - init new sync of HAs
raymondjt
Tue Mar 29, 2016 1:56 pm
already having some HA devices in a two node hyper-v converged environment, when I create a new device,
some (sometimes all, sometimes only a couple) "old already synchronized HA devices" loose the green status and need a synchronization. Sometimes it is quick, sometimes it is a full sync.
Mostly I am testing with flat images at the moment.
Is this a know feature?
THX
Raymond
PoSaP
Thu Mar 31, 2016 11:52 am
Hi
I had this feature, but only once.
And I`ve heard that should be fix for it in the next release.
Mon Apr 04, 2016 3:22 pm
Thank you for answering that PoSaP.
The thing is that it is known or not known depending on what is the reason why it goes out of sync. Can you see some latency-related records in the StarWind even logs before the devices go out of sync?
