11:52:16:875 (f7c) Srv: StarWind iSCSI Target v2.6.3 (Build 20050730, Win32)
11:52:16:875 (f7c) Srv: Licensed to: 'FREE', 'NOT COMERCIAL', (#1, 2, 0).
11:52:16:875 (f7c) Srv: Max number of client hosts: 2.
11:52:16:875 (f7c) Srv: Config file: 'C:\Program Files\RDS\StarWind\starwind.conf'
11:52:16:890 (f7c) conf: 'LogLevel' = '3'
11:52:16:890 (f7c) conf: 'LogMask' = '0x8fffffff'
11:52:16:890 (f7c) conf: 'Port' = '3260'
11:52:16:890 (f7c) conf: 'Interface' = '0.0.0.0'
11:52:16:890 (f7c) conf: 'DefTargetName' = 'iqn.2003-06.com.rocketdivision.starwind:$(host).$(symid)'
11:52:16:890 (f7c) conf: 'Login' = 'test'
11:52:16:890 (f7c) conf: 'Password' = '##CY9rzUYh03PK3k6DJie09g=='
11:52:16:890 (f7c) conf: 'Echo' = 'no'
11:52:16:890 (f7c) conf: 'MinBufferSize' = '65536'
11:52:16:890 (f7c) conf: 'AlignmentMask' = '0x0000'
11:52:16:890 (f7c) conf: 'MaxPendingRequests' = '64'
11:52:16:890 (f7c) conf: Variable 'LogLevel' is set to '3'.
11:52:16:890 (f7c) conf: Variable 'LogMask' is set to '0x8fffffff'.
11:52:16:890 (f7c) conf: Variable 'Port' is set to '3260'.
11:52:16:890 (f7c) conf: Variable 'Interface' is set to '0.0.0.0'.
11:52:16:890 (f7c) conf: Variable 'DefTargetName' is set to 'iqn.2003-06.com.rocketdivision.starwind:$(host).$(symid)'.
11:52:16:890 (f7c) conf: Variable 'Login' is set to 'test'.
11:52:16:890 (f7c) conf: Variable 'Password' is set to '##CY9rzUYh03PK3k6DJie09g=='.
11:52:16:890 (f7c) conf: Variable 'Echo' is set to 'no'.
11:52:16:890 (f7c) conf: Variable 'MinBufferSize' is set to '65536'.
11:52:16:890 (f7c) conf: Variable 'AlignmentMask' is set to '0x0000'.
11:52:16:890 (f7c) conf: Variable 'MaxPendingRequests' is set to '64'.
RamDisk[f7c] *SscPort_Init: Logging level is set to 3.
VendorId = ' '
ProductId = ' '
Revision = '0001'
11:52:16:906 (f7c) func: >>> iScsiServer::addPlugin
11:52:16:906 (f7c) func: <<< iScsiServer::addPlugin
11:52:16:906 (f7c) conf: 'RamDisk.dll' loaded successfully.
ImageFile[f7c] *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Alias: 'My Computer'
Extensions: 'img,dat'
ImageFile[f7c] *SscPort_Init: Logging level is set to 3.
VendorId = ' '
ProductId = ' '
Revision = '0001'
DefImageDir = '*\'
Volumes = 0
ExeDir = 'C:\Program Files\RDS\StarWind\'
11:52:16:937 (f7c) func: >>> iScsiServer::addPlugin
11:52:16:937 (f7c) func: <<< iScsiServer::addPlugin
11:52:16:937 (f7c) conf: 'ImageFile.dll' loaded successfully.
VirtualDVD[f7c] *SscPort_Init:
Dirname: '*'
Rights: 0x18
Extensions: 'mds,iso'
VirtualDVD[f7c] *SscPort_Init: Logging level is set to 3.
VendorId = 'ROCKET '
ProductId = 'DVD-ROM F50 '
Revision = '1.00'
DefImageDir = '*\'
11:52:16:984 (f7c) func: >>> iScsiServer::addPlugin
11:52:16:984 (f7c) func: <<< iScsiServer::addPlugin
11:52:16:984 (f7c) conf: 'VirtualDvd.dll' loaded successfully.
IBV[f7c] *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Extensions: 'ibv'
Dirname: '*'
Rights: 0x18
Alias: 'Readonly ImageFiles'
IBV[f7c] *SscPort_Init: Logging level is set to 3.
VendorId = ' '
ProductId = ' '
Revision = '0001'
ImageDir = '*\'
11:52:17:015 (f7c) func: >>> iScsiServer::addPlugin
11:52:17:015 (f7c) func: <<< iScsiServer::addPlugin
11:52:17:015 (f7c) conf: 'IBVolume.dll' loaded successfully.
11:52:17:015 (f7c) func: >>> iScsiServer::addDevice
11:52:17:015 (f7c) func: <<< iScsiServer::addDevice
11:52:17:015 (f7c) func: >>> iScsiSscDevice::open
11:52:17:015 (f7c) func: >>> iScsiPlugin::create
RamDisk[f7c] *SscPort_Create: opening device 'RamDrive0', size 16, format FAT16: yes, AWE: no, SpeedTest: no.
RamDisk[f7c] *RamDisk_Create: Creating Ram Disk: 16 MB (32768 sectors)...
RamDisk[f7c] *RamDisk_Create: Disk geometry: Sect/Track= 16, Tracks/Cyl= 32, Ncyl= 64, TotalSectors: 32768
RamDisk[f7c] *RamDisk_Create: 2 memory blocks were allocated.
RamDisk[f7c] RamDisk_WriteSectorsNormal: Write blocks: dwStartSector 0, dwSectorsToWrite 1, pBuffer 58ae00, dwBufferSize 512.
RamDisk[f7c] *RamDisk_FormatDisk: RamDisk to format: Cylinders: 64, TracksPerCylinder: 32, SectorsPerTrack: 16, BytesPerSector: 512
RamDisk[f7c] *RamDisk_FormatDisk: Ramdisk formatting: Root dir entries: 128, Sectors/cluster: 1
RamDisk[f7c] RamDisk_WriteSectorsNormal: Write blocks: dwStartSector 16, dwSectorsToWrite 1, pBuffer 981b8, dwBufferSize 512.
RamDisk[f7c] RamDisk_WriteSectorsNormal: Write blocks: dwStartSector 17, dwSectorsToWrite 128, pBuffer 983c0, dwBufferSize 65536.
RamDisk[f7c] RamDisk_WriteSectorsNormal: Write blocks: dwStartSector 145, dwSectorsToWrite 1, pBuffer a83c8, dwBufferSize 512.
RamDisk[f7c]->RamDisk_BuildInquiry >>
RamDisk[f7c] *RamDisk_BuildInquiry: Use default VendorId
RamDisk[f7c] *RamDisk_BuildInquiry: Use default ProductId
ProductId = 'RAM DISK 16 MB '
Revision = '0001'
RamDisk[f7c]<-RamDisk_BuildInquiry << Return (0x0)
11:52:17:015 (f7c) func: <<< iScsiPlugin::create
11:52:17:015 (f7c) func: >>> iScsiPlugin::getDeviceInfo
11:52:17:015 (f7c) Plugin: DevName: 'RamDrive0'
11:52:17:015 (f7c) Plugin: Param: 'size' = '16'
11:52:17:015 (f7c) Plugin: Param: 'format' = 'yes'
11:52:17:015 (f7c) Plugin: Param: 'clustered' = 'no'
11:52:17:015 (f7c) func: <<< iScsiPlugin::getDeviceInfo
11:52:17:015 (f7c) func: <<< iScsiSscDevice::open
11:52:17:015 (f7c) S: the device 'RamDrive0' is opened successfully.
11:52:17:015 (f7c) S: Assigned target name: 'iqn.2003-06.com.rocketdivision.starwind:mars.ramdisk.ramdrive0', SymId: 'RAMdisk.RamDrive0'.
11:52:17:015 (f7c) S: parameter 'size', value '16'.
11:52:17:015 (f7c) S: parameter 'format', value 'yes'.
11:52:17:015 (f7c) S: clustered 0.
11:52:17:015 (f7c) S: iqn.2003-06.com.rocketdivision.starwind:mars.ramdisk.ramdrive0: 1 session(s) allowed.
11:52:17:015 (f7c) conf: Target [0x97c18] has been created. Device 'RamDrive0' is accesible as target 'iqn.2003-06.com.rocketdivision.starwind:mars.ramdisk.ramdrive0'.
11:52:17:015 (f7c) func: >>> iScsiServer::refreshDeviceList
11:52:17:015 (f7c) Srv: Refreshing device list (complete)...
11:52:18:468 (f7c) func: >>> iScsiSptiDevice::open
11:52:18:484 (f7c) func: >>> iScsiSptiDevice::openDevice
11:52:18:484 (f7c) SPTI: '\\.\D:': Cannot open the device: The process cannot access the file because it is being used by another process. (code: 32).
11:52:18:484 (f7c) func: <<< iScsiSptiDevice::openDevice
11:52:18:484 (f7c) func: >>> iScsiSptiDevice::closeDevice
11:52:18:484 (f7c) func: <<< iScsiSptiDevice::closeDevice
11:52:18:484 (f7c) Srv: Failed to open the device '\\.\D:'.
11:52:19:015 (f7c) func: >>> iScsiSptiDevice::probe
11:52:19:015 (f7c) func: <<< iScsiSptiDevice::probe
11:52:19:015 (f7c) SPTI: '\\.\E:': DeviceType 0, DeviceTypeModifier 0, RemovableMedia false, VendorId '', ProductId 'MAXTOR 6L020J1', ProductRevision 'A93.0500', BusType 3.
11:52:19:015 (f7c) SPTI: '\\.\E:': MaximumTransferLength 131072, MaximumPhysicalPages 0xffffffff, AlignmentMask 0x1, BusType 3, CommandQueueing 0.
11:52:19:015 (f7c) SPTI: '\\.\E:': ' MAXTOR 6L020J1 A93.0500': adapter 0, bus 0, target id 0, LUN 0; maxTransferLength 131072
11:52:19:015 (f7c) func: >>> iScsiSptiDevice::getBurnerFlags
11:52:19:015 (f7c) func: <<< iScsiSptiDevice::getBurnerFlags
11:52:19:015 (f7c) func: <<< iScsiSptiDevice::openDevice
11:52:19:015 (f7c) func: >>> iScsiSptiDevice::closeDevice
11:52:19:015 (f7c) func: <<< iScsiSptiDevice::closeDevice
11:52:19:031 (f7c) func: <<< iScsiSptiDevice::open
11:52:19:031 (f7c) Srv: '\\.\E:': hard drive may not be accessed through '\\.\<X>:' symlink.
11:52:19:031 (f7c) Srv: '\\.\E:' is not allowed by the server.
11:52:19:031 (f7c) func: >>> iScsiSptiDevice::close
11:52:19:031 (f7c) func: <<< iScsiSptiDevice::close
11:52:19:031 (f7c) func: >>> iScsiSptiDevice::open
11:52:19:031 (f7c) func: >>> iScsiSptiDevice::openDevice
11:52:20:000 (f7c) func: >>> iScsiSptiDevice::probe
11:52:20:000 (f7c) func: <<< iScsiSptiDevice::probe
11:52:20:000 (f7c) SPTI: '\\.\F:': DeviceType 0, DeviceTypeModifier 0, RemovableMedia false, VendorId '', ProductId 'MAXTOR 6L020J1', ProductRevision 'A93.0500', BusType 3.
11:52:20:000 (f7c) SPTI: '\\.\F:': MaximumTransferLength 131072, MaximumPhysicalPages 0xffffffff, AlignmentMask 0x1, BusType 3, CommandQueueing 0.
11:52:20:000 (f7c) SPTI: '\\.\F:': ' MAXTOR 6L020J1 A93.0500': adapter 0, bus 0, target id 1, LUN 0; maxTransferLength 131072
11:52:20:000 (f7c) func: >>> iScsiSptiDevice::getBurnerFlags
11:52:20:000 (f7c) func: <<< iScsiSptiDevice::getBurnerFlags
11:52:20:000 (f7c) func: <<< iScsiSptiDevice::openDevice
11:52:20:000 (f7c) func: >>> iScsiSptiDevice::closeDevice
11:52:20:000 (f7c) func: <<< iScsiSptiDevice::closeDevice
11:52:20:000 (f7c) Srv: '\\.\F:': hard drive may not be accessed through '\\.\<X>:' symlink.
11:52:20:000 (f7c) Srv: '\\.\F:' is not allowed by the server.
11:52:20:015 (f7c) func: >>> iScsiSptiDevice::open
11:52:20:015 (f7c) func: >>> iScsiSptiDevice::openDevice
11:52:20:015 (f7c) func: >>> iScsiSptiDevice::probe
11:52:20:015 (f7c) func: <<< iScsiSptiDevice::probe
11:52:20:015 (f7c) SPTI: '\\.\R:': DeviceType 5, DeviceTypeModifier 0, RemovableMedia true, VendorId '', ProductId 'HL-DT-ST DVD-ROM GDR8163B', ProductRevision '0L23', BusType 2.
11:52:20:015 (f7c) SPTI: '\\.\R:': MaximumTransferLength 131072, MaximumPhysicalPages 0xffffffff, AlignmentMask 0x1, BusType 3, CommandQueueing 0.
11:52:20:015 (f7c) SPTI: '\\.\R:': ' HL-DT-ST DVD-ROM GDR8163B 0L23': adapter 1, bus 0, target id 0, LUN 0; maxTransferLength 131072
11:52:20:015 (f7c) func: >>> iScsiSptiDevice::getBurnerFlags
11:52:20:031 (f7c) func: <<< iScsiSptiDevice::getBurnerFlags
11:52:20:031 (f7c) func: <<< iScsiSptiDevice::openDevice
11:52:20:031 (f7c) func: >>> iScsiSptiDevice::closeDevice
11:52:20:031 (f7c) func: <<< iScsiSptiDevice::closeDevice
11:52:20:031 (f7c) Srv: Found SPTI device '\\.\R:': ' HL-DT-ST DVD-ROM GDR8163B 0L23'
11:52:20:031 (f7c) func: >>> iScsiServer::addDevice
11:52:20:031 (f7c) func: <<< iScsiServer::addDevice
11:52:20:031 (f7c) func: >>> iScsiSptiDevice::open
11:52:20:031 (f7c) func: >>> iScsiSptiDevice::openDevice
11:52:20:046 (f7c) func: >>> iScsiSptiDevice::probe
11:52:20:046 (f7c) func: <<< iScsiSptiDevice::probe
11:52:20:046 (f7c) SPTI: '\\.\V:': DeviceType 5, DeviceTypeModifier 0, RemovableMedia true, VendorId '', ProductId 'HL-DT-ST DVDRAM GSA-4082B', ProductRevision 'A209', BusType 2.
11:52:20:046 (f7c) SPTI: '\\.\V:': MaximumTransferLength 131072, MaximumPhysicalPages 0xffffffff, AlignmentMask 0x1, BusType 3, CommandQueueing 0.
11:52:20:046 (f7c) SPTI: '\\.\V:': ' HL-DT-ST DVDRAM GSA-4082B A209': adapter 1, bus 0, target id 1, LUN 0; maxTransferLength 131072
11:52:20:046 (f7c) func: >>> iScsiSptiDevice::getBurnerFlags
11:52:20:062 (f7c) func: <<< iScsiSptiDevice::getBurnerFlags
11:52:20:062 (f7c) func: <<< iScsiSptiDevice::openDevice
11:52:20:062 (f7c) func: >>> iScsiSptiDevice::closeDevice
11:52:20:062 (f7c) func: <<< iScsiSptiDevice::closeDevice
11:52:20:062 (f7c) Srv: Found SPTI device '\\.\V:': ' HL-DT-ST DVDRAM GSA-4082B A209'
11:52:20:062 (f7c) func: >>> iScsiServer::addDevice
11:52:20:062 (f7c) func: <<< iScsiServer::addDevice
11:52:20:078 (f7c) func: >>> iScsiSptiDevice::open
11:52:20:078 (f7c) func: >>> iScsiSptiDevice::openDevice
11:52:20:078 (f7c) func: >>> iScsiSptiDevice::probe
11:52:20:078 (f7c) func: <<< iScsiSptiDevice::probe
11:52:20:078 (f7c) SPTI: '\\.\Cdrom0': DeviceType 5, DeviceTypeModifier 0, RemovableMedia true, VendorId '', ProductId 'HL-DT-ST DVD-ROM GDR8163B', ProductRevision '0L23', BusType 2.
11:52:20:078 (f7c) SPTI: '\\.\Cdrom0': MaximumTransferLength 131072, MaximumPhysicalPages 0xffffffff, AlignmentMask 0x1, BusType 3, CommandQueueing 0.
11:52:20:078 (f7c) SPTI: '\\.\Cdrom0': ' HL-DT-ST DVD-ROM GDR8163B 0L23': adapter 1, bus 0, target id 0, LUN 0; maxTransferLength 131072
11:52:20:078 (f7c) func: >>> iScsiSptiDevice::getBurnerFlags
11:52:20:093 (f7c) func: <<< iScsiSptiDevice::getBurnerFlags
11:52:20:093 (f7c) func: <<< iScsiSptiDevice::openDevice
11:52:20:093 (f7c) func: >>> iScsiSptiDevice::closeDevice
11:52:20:093 (f7c) func: <<< iScsiSptiDevice::closeDevice
11:52:20:093 (f7c) Srv: SPTI device '\\.\Cdrom0' is an alias of '\\.\R:'
11:52:20:093 (f7c) Srv: '\\.\Cdrom0' is not allowed by the server.
11:52:20:093 (f7c) func: >>> iScsiSptiDevice::open
11:52:20:093 (f7c) func: >>> iScsiSptiDevice::openDevice
11:52:20:109 (f7c) func: >>> iScsiSptiDevice::probe
11:52:20:125 (f7c) func: <<< iScsiSptiDevice::probe
11:52:20:125 (f7c) SPTI: '\\.\Cdrom1': DeviceType 5, DeviceTypeModifier 0, RemovableMedia true, VendorId '', ProductId 'HL-DT-ST DVDRAM GSA-4082B', ProductRevision 'A209', BusType 2.
11:52:20:125 (f7c) SPTI: '\\.\Cdrom1': MaximumTransferLength 131072, MaximumPhysicalPages 0xffffffff, AlignmentMask 0x1, BusType 3, CommandQueueing 0.
11:52:20:125 (f7c) SPTI: '\\.\Cdrom1': ' HL-DT-ST DVDRAM GSA-4082B A209': adapter 1, bus 0, target id 1, LUN 0; maxTransferLength 131072
11:52:20:125 (f7c) func: >>> iScsiSptiDevice::getBurnerFlags
11:52:20:125 (f7c) func: <<< iScsiSptiDevice::getBurnerFlags
11:52:20:125 (f7c) func: <<< iScsiSptiDevice::openDevice
11:52:20:125 (f7c) func: >>> iScsiSptiDevice::closeDevice
11:52:20:125 (f7c) func: <<< iScsiSptiDevice::closeDevice
11:52:20:125 (f7c) Srv: SPTI device '\\.\Cdrom1' is an alias of '\\.\V:'
11:52:20:125 (f7c) Srv: '\\.\Cdrom1' is not allowed by the server.
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive0': Hard drive name: '\\.\PhysicalDrive0'
11:52:20:125 (f7c) func: >>> iScsiSptiDevice::open
11:52:20:125 (f7c) func: >>> iScsiSptiDevice::openDevice
11:52:20:125 (f7c) func: >>> iScsiSptiDevice::probe
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive0': DeviceType 0, DeviceTypeModifier 0, RemovableMedia false, VendorId '', ProductId 'MAXTOR 6L020J1', ProductRevision 'A93.0500', BusType 3.
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive0': MaximumTransferLength 131072, MaximumPhysicalPages 0xffffffff, AlignmentMask 0x1, BusType 3, CommandQueueing 0.
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive0': ' MAXTOR 6L020J1 A93.0500': adapter 0, bus 0, target id 0, LUN 0; maxTransferLength 131072
11:52:20:125 (f7c) Srv: Found SPTI device '\\.\PhysicalDrive0': ' MAXTOR 6L020J1 A93.0500'
11:52:20:125 (f7c) func: >>> iScsiServer::addDevice
11:52:20:125 (f7c) func: <<< iScsiServer::addDevice
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive1': Hard drive name: '\\.\PhysicalDrive1'
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive1': DeviceType 0, DeviceTypeModifier 0, RemovableMedia false, VendorId '', ProductId 'MAXTOR 6L020J1', ProductRevision 'A93.0500', BusType 3.
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive1': MaximumTransferLength 131072, MaximumPhysicalPages 0xffffffff, AlignmentMask 0x1, BusType 3, CommandQueueing 0.
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive1': ' MAXTOR 6L020J1 A93.0500': adapter 0, bus 0, target id 1, LUN 0; maxTransferLength 131072
11:52:20:125 (f7c) Srv: Found SPTI device '\\.\PhysicalDrive1': ' MAXTOR 6L020J1 A93.0500'
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive2': Hard drive name: '\\.\PhysicalDrive2'
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive2': DeviceType 0, DeviceTypeModifier 0, RemovableMedia false, VendorId 'IBM ', ProductId 'DPSS-318350N ', ProductRevision 'S96H', BusType 1.
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive2': MaximumTransferLength 16777215, MaximumPhysicalPages 0x11, AlignmentMask 0x0, BusType 1, CommandQueueing 1.
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive2': 'IBM DPSS-318350N S96H': adapter 2, bus 0, target id 0, LUN 0; maxTransferLength 65536
11:52:20:125 (f7c) Srv: Found SPTI device '\\.\PhysicalDrive2': 'IBM DPSS-318350N S96H'
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive3': Hard drive name: '\\.\PhysicalDrive3'
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive3': DeviceType 0, DeviceTypeModifier 0, RemovableMedia false, VendorId 'IBM ', ProductId 'DPSS-318350N ', ProductRevision 'S96H', BusType 1.
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive3': MaximumTransferLength 16777215, MaximumPhysicalPages 0x11, AlignmentMask 0x0, BusType 1, CommandQueueing 1.
11:52:20:125 (f7c) SPTI: '\\.\PhysicalDrive3': 'IBM DPSS-318350N S96H': adapter 2, bus 0, target id 1, LUN 0; maxTransferLength 65536
11:52:20:125 (f7c) Srv: Found SPTI device '\\.\PhysicalDrive3': 'IBM DPSS-318350N S96H'
11:52:20:125 (f7c) func: >>> iScsiPlugin::enumerateDevices
11:52:20:125 (f7c) func: <<< iScsiPlugin::enumerateDevices
ImageFile[f7c] SscPort_EnumerateDevices: force: 1
ImageFile[f7c] SscPort_EnumerateDevices: force: 0
11:52:20:125 (f7c) func: <<< iScsiServer::refreshDeviceList
11:52:20:125 (f7c) func: >>> iScsiServer::listenConnections
11:52:20:156 (fbc) func: >>> TelnetListener::listenConnections
11:52:20:156 (f7c) Srv: Binding to 0.0.0.0:3260 ...
11:52:20:281 (f7c) Srv: Waiting for a connection at port 0.0.0.0:3260 ...
11:52:20:281 (fbc) conf: Waiting for a control connection at port 3261 ...
11:52:21:875 (f78) ntsrv: Got SERVICE_CONTROL_INTERROGATE signal.
11:52:48:625 (fbc) conf: Accepted the control connection from 127.0.0.1:1034.
11:52:48:625 (954) func: >>> ControlConnection::doLogon
11:52:48:625 (954) func: <<< ControlConnection::doLogon
