3/19 21:04:57.067 488 Sp: Creating LSFS device:
Directory: X:\Storage1\
Prefix: Storage1
Exisiting: 0
Read-only: 0
Block size: 4096
Size in blocks: 314572800
Page size: 4194304
Pages per superpage: 0
Threads: 1
Packets: 256
DD disabled: 0
Defrag: 0
Verify: 0
3/19 21:04:57.067 488 CACHE: *** CacheBase::init: Cache parameters: Mode = 3, Flags = 64, Size = 16 MB, SectorSize = 512, BlockExpiryPeriod = 5000, DiskSizeInSectors = 0, Blocks = 0x0000000006F7ABD0
3/19 21:04:57.067 488 Sp: *** CStarPackSpaceSegmentFile::GenerateHeader Failed to write header of segment! Status (21)
3/19 21:04:57.067 488 Sp: --- CStarPackSpaceSegmentFile::GenerateHeader() (line #2081) 21
3/19 21:04:57.067 488 Sp: *** CStarPackSpaceSegmentFile::OpenSuperPageFile Failed to write header to segment file 'X:\Storage1\\Storage1.spsp'! Status (21)
3/19 21:04:57.082 488 Sp: *** CStarPackSpaceSegmentFile::PrepareSegment Failed to open file 'X:\Storage1\\Storage1.spsp' for segment '0'! Status (21)
3/19 21:04:57.082 488 Sp: --- CStarPackSpaceSegmentFile::PrepareSegment(Segment index - 0, Size in pages - 128, Page size - 4194304, 0x000000000250E1F0) (line #248) 21
3/19 21:04:57.082 488 Sp: *** CStarPackSpaceSegmentFile::Initialize Failed to prepare segment '0'! Status (21)
.314 904 Sw: DDDisk_DeviceInfo: LSFS device 'lsfs1': mounting progress '99'.
3/6 0:35:26.642 eb0 Sw: *** DDDisk_DispatchLimited: Got command 0xF1 when device state is not DD_DISK_CREATION_COMPLETE! Current state is 2.
3/6 0:35:27.236 ad8 Sp: *** SpCoreObjectCreateFromParams 31 0x000000690C244A70 *ppCore->pCore->Create( 0x0000006CF6D1E620 ) 31
3/6 0:35:27.236 ad8 Sp: --- SpCoreObjectCreateFromParams(0x000000690C244A70, 0x0000006CF6D1E620) (line #4479) 31
3/6 0:35:27.252 ad8 Sw: *** DDDisk_Mount: Failed to create SP object, error ( 31 ).
3/6 0:35:27.314 be0 Sw: DDDisk_Mount:
Create SP object: Storage path ( 'E:\NVME4\\NVME4' ), Open existing storage ( yes ),
Threads ( 8 ), Packets ( 16 ),
Data Cache size ( 10240 KB, ~10 MB ), Map cache size ( 29734 KB, ~29 MB ), Metadata cache size ( 16384 KB, ~16 MB ),
Data deletion ( yes ), Verification ( no ).
3/6 0:35:27.330 be0 Sp: Creating LSFS device:
Directory: E:\NVME4\
Prefix: NVME4
Exisiting: 1
Read-only: 1
Block size: 4096
Page size: 4194304
Threads: 8
Packets: 256
DD disabled: 0
Defrag: 1
Verify: 0
3/6 0:35:27.423 be0 Sw: *** sw_common::Sw_CompletionPort::Open: There are 12 processor cores detected in the system. 4 worker threads will be created for completion of asynchronous IO operations.
3/6 0:35:27.439 be0 Sw: *** sw_common::Sw_CompletionPort::Open: Set IO Completion thread (0x0000000000000310, id=3460) affinity: group = 0x0, mask = 0xaaa
3/6 0:35:27.439 be0 Sw: *** sw_common::Sw_CompletionPort::Open: Set IO Completion thread (0x0000000000007028, id=1760) affinity: group = 0x0, mask = 0xaaa
3/6 0:35:27.439 be0 Sw: *** sw_common::Sw_CompletionPort::Open: Set IO Completion thread (0x0000000000004F84, id=3920) affinity: group = 0x0, mask = 0xaaa
3/6 0:35:27.439 be0 Sw: *** sw_common::Sw_CompletionPort::Open: Set IO Completion thread (0x0000000000003698, id=7708) affinity: group = 0x0, mask = 0xaaa
3/6 0:35:27.470 be0 CACHE: CacheBase::CacheBase: StarWind Virtual SAN v8.0.0 (Build 10695, [SwSAN], Win64)
3/6 0:35:27.486 be0 CACHE: CacheBase::CacheBase: Feb 16 2017 20:35:24
3/6 0:35:27.814 be0 CACHE: *** CacheBase::init: Cache parameters: Mode = 3, Flags = 64, Size = 16 MB, SectorSize = 512, BlockExpiryPeriod = 5000, DiskSizeInSectors = 0, Blocks = 0x0000006FD9EE25C0
3/6 0:35:27.877 be0 CACHE: CacheBase::init: Worker Thread is started and set to affinity group: 820.
3/6 0:35:27.892 be0 Sw: *** sw_common::Sw_CompletionPort::Open: There are 12 processor cores detected in the system. 4 worker threads will be created for completion of asynchronous IO operations.
3/6 0:35:27.892 be0 Sw: *** sw_common::Sw_CompletionPort::Open: Set IO Completion thread (0x0000000000000348, id=400) affinity: group = 0x0, mask = 0xaaa
3/6 0:35:27.892 be0 Sw: *** sw_common::Sw_CompletionPort::Open: Set IO Completion thread (0x0000000000000344, id=10180) affinity: group = 0x0, mask = 0xaaa
3/6 0:35:27.892 be0 Sw: *** sw_common::Sw_CompletionPort::Open: Set IO Completion thread (0x00000000000002DC, id=7576) affinity: group = 0x0, mask = 0xaaa
3/6 0:35:27.892 be0 Sw: *** sw_common::Sw_CompletionPort::Open: Set IO Completion thread (0x00000000000009E8, id=8832) affinity: group = 0x0, mask = 0xaaa
3/6 0:35:27.908 be0 Sp: *** CStarPackCore::CreateEx Header version is 10
3/6 0:35:27.939 be0 Sp: *** CStarPackCore::CreateEx Both superblocks are valid
3/6 0:35:28.002 be0 Sp: *** CStarPackSpaceSegmentFile::PrepareSegment Failed to open file 'E:\NVME4\\NVME4_147089.spspx' for segment '147089'! Status (2)
3/6 0:35:28.002 be0 Sp: --- CStarPackSpaceSegmentFile::PrepareSegment(Segment index - 147089, Size in pages - 128, Page size - 4194304, 0x0000007055B23580) (line #252) 2
3/6 0:35:28.002 be0 Sp: *** CStarPackSpaceSegmentFile::Initialize Segment '147089' created as 'Phantome'!
3/6 0:35:28.002 be0 Sp: *** CStarPackCore::GetActualLastPage Device updated to the state at page [18827391]
3/6 0:35:28.017 be0 Sp: Opened header of LSFS device:
Prefix: NVME4
Read-only: 1
Block size: 4096
Map chunk size: 4096
VMap size: 714429441
Page size: 4194304
DD used: 1
Defrag used: 1
VMap outdated: 1
LUMaps outdated: 1
3/6 0:35:28.080 be0 Sp: *** CStarPackCore::OpenMapFullDumpFile Full map dump file [E:\NVME4\\NVME4.spvmap] does not exist
3/6 0:35:28.080 be0 Sp: *** CStarPackCore::OpenVirtualMap Full dump restore from file failed. Status [80]
3/6 0:35:29.658 eb0 Sw: *** DDDisk_DispatchLimited: Got command 0xF1 when device state is not DD_DISK_CREATION_COMPLETE! Current state is 0.
3/6 0:35:32.674 eb0 Sw: *** DDDisk_DispatchLimited: Got command 0xF1 when device state is not DD_DISK_CREATION_COMPLETE! Current state is 0.
3/6 0:35:35.689 eb0 Sw: *** DDDisk_DispatchLimited: Got command 0xF1 when device state is not DD_DISK_CREATION_COMPLETE! Current state is 0.
2/5 23:34:14.474 d54 func: >>> CHADevice::CreateDevice
2/5 23:34:14.474 d54 HA: CHADevice::CreateDevice: Params(Device = 0x0000018A3500C980, TargetName = iqn.2008-08.com.starwindsoftware:hyperv2.gatorhome.net-esxi, ImageFile = E:\ESXi\ESXi_HA.swdsk, DevName = lsfs1, p_pStorageDeviceInterface = 0x0000018A341D9C30,SectorsPerTrack = 0, TracksPerCylinder = 0, SerialIdStr = 6E95C29115FC8326, Storage = 0x0000000000000000, StorageLimits = 0x00000038FCF7F148,p_pfuncSscPort_Create = 0x0000000000000000, p_pfuncSscPort_Close = 0x0000000000000000,p_pfuncSscPort_Prepare = 0x0000000000000000, p_pfuncSscPort_Dispatch = 0x0000000000000000, p_pfuncSscPort_CommandCompleted = 0x0000000000000000, p_pfuncSscPort_ControlRequest = 0x0000000000000000, p_pfuncSscPort_RegisterSession = 0x0000000000000000, p_pfuncSscPort_UnregisterSession = 0x0000000000000000, p_pfuncSscPort_GetDeviceInfo = 0x0000000000000000,AlUANodeGroupStates = 0,0) ENTERed
2/5 23:34:14.474 d54 Common: sw_common::Sw_Disk_Header::open(file: E:\ESXi\ESXi_HA.swdsk, readonly: no).
2/5 23:34:14.489 d84 CACHE: CacheBase::CacheBase: StarWind Virtual SAN v8.0.0 (Build 11818, [SwSAN], Win64)
2/5 23:34:14.489 d84 CACHE: CacheBase::CacheBase: Dec 14 2017 19:53:55
2/5 23:34:14.489 d84 CACHE: CacheBase::init: Cache parameters: Mode = 3, Flags = 64, Size = 1024 MB, SectorSize = 512, BlockExpiryPeriod = 5000, DiskSizeInSectors = 0, Blocks = 0x0000018A34FDEC40
2/5 23:34:14.489 d84 CACHE: CacheBase::init: Prefetch Advisor was not created for RAM Cache!
2/5 23:34:14.489 d84 CACHE: CacheBase::init: Worker Thread is started and set to affinity group: 1208.
2/5 23:34:14.489 d84 CACHE: CacheBase::init: Worker Thread is started and set to affinity group: 1240.
2/5 23:34:14.489 d84 CACHE: CacheBase::init: Worker Thread is started and set to affinity group: 1244.
2/5 23:34:14.489 d84 Sp: xxx SpThreadObjectCreate (296) Thread 0x4e0(3488) affinity set to group = 0 and mask = 0x000000000000000F
2/5 23:34:14.489 d84 Sp: xxx SpThreadObjectCreate (296) Thread 0x4e8(3492) affinity set to group = 0 and mask = 0x000000000000000F
2/5 23:34:14.489 d84 Sp: xxx SpThreadObjectCreate (296) Thread 0x4f0(3496) affinity set to group = 0 and mask = 0x000000000000000F
2/5 23:34:14.489 d84 Sw: *** sw_common::Sw_CompletionPort::Open: There are 4 processor cores detected in the system. 2 worker threads will be created for completion of asynchronous IO operations.
2/5 23:34:14.489 d84 Sw: *** sw_common::Sw_CompletionPort::Open: Set IO Completion thread (0x0000000000000500, id=3500) affinity: group = 0x0, mask = 0xf
2/5 23:34:14.489 d84 Sw: *** sw_common::Sw_CompletionPort::Open: Set IO Completion thread (0x00000000000004FC, id=3504) affinity: group = 0x0, mask = 0xf
2/5 23:34:14.489 d84 Sp: *** CStarPackCoreNew::CStarPackCore::CheckCoreVersion (1751) (0x0000018A35840000) Core Object [0000018A35840000] is compatible with passed storage.
LibVersion = 1, SpCoreVersion = 10. StorageLibVersion = 1, StorageCoreVersion = 10.
2/5 23:34:14.489 d64 Plugin: GetServerComponentsAsync RequestState - 100 of 100, 1, 0
2/5 23:34:14.489 d54 HA: MaintenanceMode::initialize: Maintenance mode is 'off'.
2/5 23:34:14.489 db4 Sw: *** DDDisk_DispatchLimited: Got command 0x00 when device state is not DD_DISK_CREATION_COMPLETE! Current state is 2.
2/5 23:34:14.489 db4 SWSD: CStarWindStorageDevice::SendTestUnitReadyCommand: ForwardSscCommand() return not successfull SCSI status 2!
2/5 23:34:14.505 d54 HA: CHADevice::CreateDevice: EXITing with failure(112): m_haHeader.sync() failed unable to overwrite the geometry data by corresponding values of the underlying storage!
2/5 23:34:14.505 d54 func: <<< CHADevice::CreateDevice
2/5 23:34:14.505 d54 HA: Create('My Computer\E\ESXi\ESXi_HA.swdsk') error (0xc0000001)!
2/5 23:34:14.505 d54 func: >>> CHADevice::CloseDevice
2/5 23:34:14.505 d54 HA: CHADevice::CloseDevice: Closing the device 0x0000018A3500C980, target name iqn.2008-08.com.starwindsoftware:hyperv2.gatorhome.net-esxi, flags 0x0.
2/5 23:34:14.505 d54 SCHED: Sw_Scheduler::detach: The 0x0000000000000000:0x0 device unit is being deregistered at the Scheduler.
