VSAN OVF Questions
epalombizio
Wed Jan 27, 2016 10:14 pm
All,
The VSA that I downloaded from the Starwind customer area uses VM Hardware version 8, as well as E1000E type network adapters. Does Starwind have a recommendation against upgrading the VM hardware version 11, or using VMXNET3 adapters?
epalombizio
Thu Jan 28, 2016 3:46 pm
Well, since I can't activate the evaluation edition with my VL key, I'll need to follow a different path.
Starwind: Do you have any recommended docs/tweaks that need to be made to a fresh installation of Windows 2012 R2 for exclusive use as a VSA?
Darklight, I still have your recommendations from another post which I'll be using.. thanks for that.
darklight
Wed Feb 03, 2016 4:19 pm
Sure thing, mate :)
Should you have any further questions, go ahead, i will gladly help :)
Tarass (Staff)
Wed Feb 10, 2016 4:28 pm
Thanks guys!
Any questions left here?
StarWind Software Inc.
