LSFS/Deduplication Update
david.buchanan
Tue Dec 01, 2015 10:35 am
Hi All,
I was after an update on when a few features for Starwinds may be coming out.
1 - Expanding a LSFS De-duplicated volume.
2 - Support for larger than 11TB.
My understanding from reading the forums is that LSFS does not appear to be production ready.
To give you an idea on my set-up/requirements. I have around 90TB of Veeam backups which I'm currently using with Server 2012 R2 Post-processing de-duplication. I'm looking for a was to do this de-duplication in-line.
I assume that Starwinds still does not support a volume this large? or does it?
David
darklight
Tue Dec 01, 2015 6:09 pm
AFAIK Veeam dedupes (compresses) it's own backups already. So you want to dedupe already compressed data once again?
Tarass (Staff)
Tue Dec 08, 2015 11:58 am
Hi guys, any further questions left here?
StarWind Software Inc.
fbifido
Sat Jan 16, 2016 9:44 am
david.buchanan wrote:Hi All,
Tarass, What would be a good recommended setup for David, with his current setup?
Thanks.
Tarass (Staff)
Wed Jan 20, 2016 1:51 pm
Unfortunately single LSFS device is limited by 11TB right now and not expandable yet (expected in the future builds), however, you can still create a couple of them. If you would like to use an in-line deduplication for VEEAM backups it would be better to disable deduplication in VEEAM and let StarWind LSFS do the job.
