SW8, Fusion IO card usage
dwright1542
Tue Nov 17, 2015 8:42 pm
New SW Build, SW V 8
2xDL385G8, 192GB RAM
8x600GB, RAID 6
All 10G Backend
I've got 640GB Fusion IO cards that can be fully used for L2 cache in each server
Should they be used as datastores, then added to the starwind VM's as drives or should they be passed thru with PCI VMDirectPath to the SWIND VM so vmware doesn't see them?
Any thoughts?
darklight
Wed Nov 18, 2015 10:31 am
There is no difference in performance for sure. So you can configure it according to your wishes. I prefer using vmdk since it's just more flexible in terms of possible reconfiguration/storage provisioning.
Tarass (Staff)
Mon Nov 23, 2015 10:59 am
Valid point, Darklight, thank you!
StarWind Software Inc.
