v8.0.8198 Uninstall JUST VSS Provider
jtmroczek
Tue Aug 18, 2015 12:48 am
Hello:
I am troubleshooting an odd issue and want to try uninstalling the hardware VSS provider. OS is 2012 R2 Datacenter.
Is there a way to uninstall or at least disable the provider without completely uninstalling StarWind? The machine is both a HA StarWind Host and HA Hyper-V host. Both hosts are experiencing the same odd issue with snapshots.
~joe
Oles (staff)
Thu Aug 20, 2015 11:03 am
Hello!
Did you try stopping VSS provider service?
