Greetings,
I am currently using Starwind version 6.0.5713 with no HA and it is very stable. Can i upgrade this version to the latest version 8? I will still using it as only 1 node. Do you recommend that i do a fresh install with using the current img file or upgrade it?
Could you please describe the advantages/performance using the latest version?
Regards.
