Max image file size publishable?
Locked
Brandon
Mon Jul 18, 2005 8:56 pm
I'm using 2.6.1 and created a 1.5TB (1500GB) file with mksparse and published it.
On a W2K3 server using the MS Initiator 1.06 the published device only mounts as a 1023GB disk. I also tried the 2.6.1 version of Starport and achieved the same result.
Is this a limitation of StarWind or the Initiators?
Brandon,
Mon Jul 18, 2005 8:59 pm
Maximum supported volume size under current versions of Windows is 2TB. You current limitation hit seems to be a StarWind bug (there has been some other reports as well). We would check this. Thanks a lot for letting us know!
Brandon wrote:I'm using 2.6.1 and created a 1.5TB (1500GB) file with mksparse and published it.
Brandon,
Val (staff)
Tue Jul 19, 2005 5:20 am
Yes, this is a limitation of that StarWind version. It have been removed in the recent version 2.6.3 that is going to be released this week.
Valeriy
Brandon
Tue Jul 19, 2005 4:08 pm
Excellent!
Thanks for such outstanding support.
Brandon,
Tue Jul 19, 2005 6:30 pm
No problem! You can drop us a line to info@rocketdivision.com and we'll be happy to issue you with preview version. Thanks!
Brandon wrote:Excellent!
Brandon,
Brandon
Wed Jul 20, 2005 5:43 pm
Thanks guys, 2.6.3 works fine and the image shows up as 1.5TB on the initiator.
Brandon,
Wed Jul 20, 2005 8:32 pm
Very good! So we'll mark this one as "fixed" :)
Brandon wrote:Thanks guys, 2.6.3 works fine and the image shows up as 1.5TB on the initiator.
Brandon,
Locked
