help me!
Locked
foxsite
Sun Jul 17, 2005 4:19 pm
i get error messages as follows:
15:07:46:093 (484) SPTI: '\\.\Physicaldrive0': DeviceIoControl failed: 由于 I/O 设备错误,无法运行此项请求。 (code: 1117).
15:07:46:093 (484) SPTI: '\\.\Physicaldrive0': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
0000 2c 00 00 00 00 00 06 12 01 00 00 00 c0 00 00 00 ,...........?..
0010 e0 a5 01 00 60 d5 2b 00 2c 00 00 00 1a 00 1c 00 啷..`?.,.......
0020 c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ?..............
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
15:07:46:093 (484) SPTI: '\\.\Physicaldrive0': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
help???????
Val (staff)
Sun Jul 17, 2005 9:53 pm
Hi!
You can't to use the system hard drive in the SPTI mode. This mode demands the volume is accessed in exclusive mode - so it fails with a system drive.
I'd suggest you to use the ImageFile plug-in to create virtuals volume(s) over the disk partition and export the volumes as iSCSI targets.
Valeriy
foxsite
Sun Jul 17, 2005 11:48 pm
I really can't get you
what plugin?I don't find it
can you say it clearly?
Val (staff)
Mon Jul 18, 2005 9:45 am
foxsite wrote:I really can't get you
What is your StarWind license?
You need a Professional license to use the ImageFile plug-in.
(The trial version allows all the plugins and unlimited connections.)
To create and export an ImageFile target chose 'ImageFile' in the 'Add device' dialog. In the following step you need to specify location of the ImageFile? its size and mark the flag 'Create if not exists' to allocate disk space for the image.
BTW Reading manuals could help sometimes. ;)
Please let us know if you have any problems with StarWind.
Valeriy
Locked
