Cluster Volume Storage Disappear
lucki
Mon Jul 20, 2015 10:31 am
My cluster volume storage disappeared, in urgent need of help.
after a failure, after synchronization cluster volume storage location is not showing up anymore
please advise.
Set-up
2-node Hyper-V Failover Cluster
Windows 2012 R2
LSFS file structure
Is there a tool to extract the file contained in the cluster shared volume?
lucki
Mon Jul 20, 2015 1:36 pm
i was reading other thread which shows you guys have a utility to extract data from lslf file system, if you are able to provide that it would be awesome
darklight
Tue Jul 21, 2015 8:23 am
The first advice would be to copy and mount this device as a standalone one. Then use any Partition Recovery or Data Recovery tool on it. Since it's NTFS it mostly works. Worked for me some time ago.
lucki
Sun Jul 26, 2015 10:11 pm
darklight, what was the recovery tool that you used?
did you recovery the vhd or the file residing inside a vhd (or esxi equivalent)
darklight
Tue Jul 28, 2015 5:08 pm
Hi Lucki, unfortunately, I do not remember.
I seem it was GetDataBack or something like that. Recovering VHD or files inside VHD container depends on the tool you are using only. But both is possible I assume.
Tarass (Staff)
Tue Aug 11, 2015 10:49 am
Darklight, thanks a lot for sharing your experience with us.
Lucki, is there anything else we can help you with?
