SW 5.8 HA LUN Expansion not working (Need process)
vikeswin1
Tue Jun 30, 2015 8:40 pm
Hello all,
I'm looking for the steps to expand my HA Lun on SW 5.8 Native San.
I'm also looking for steps on how to upgrade from SW 5.8 to a newer version.
I'm currently running the following:
Node 1: W2K8 R2 - Core
Node 2: W2K8 R2 - Full Gui
Starwind: NativeSAN 5.8. (Rock solid btw just runs :mrgreen: )
I did attempt just expanding the HA LUN, a small gear appeared, and seemed to be working, but nothing happend.
I did verify via disk manager that i was not able to expand the .img disk / file.
I did reattempt expand with the CSV shutdown, obviously no luck.
I read some folks saying you need to recreate the HA LUN, or take it offline to expand.
V
darklight
Wed Jul 01, 2015 11:24 am
Wow, 5.8 it's something i am not able to remember anymore, so i have a great advice for you - UPDATE :)
If the extending does not work for you, just create another (larger) device and transfer data to it. It's bit of mess of course, but works for me :)
vikeswin1
Wed Jul 01, 2015 3:43 pm
darklight wrote:Wow, 5.8 it's something i am not able to remember anymore, so i have a great advice for you - UPDATE :)
As i stated above If someone can provide an upgrade process, that would be great!
Do i just download v8, and it will magically upgrade from 5.8, or do i need to upgrade to 6.0, the 8.0?
What's the process, or better yet what's the process, or old documentation in regards to just expanding the 5.8 LUN it works.
Vladislav (Staff)
Mon Jul 06, 2015 4:33 pm
Thank you darklight :)
vikeswin1
Tue Jul 07, 2015 6:18 pm
Yes thank you Darklight.
Vladislav (Staff)
Fri Jul 10, 2015 11:41 am
:wink:
