Poor replication performance with StarWind 8 and Intel 10GbE
dcadler
Thu Jun 25, 2015 3:41 pm
First let me start by saying this is my first experience with clustering, CSVs, vSANs, StarWind and iSCSI so if I am missing something obvious, please forgive my ignorance.
I am testing out StarWind v8 build 8116. I have two brand new identical Supermicro servers, each with the following configuration;
• Supermicro X9DRH-iF Motherboard
• Dual Intel Xeon E5-2650X2 Processors
• 256GB RAM
• 16x Seagate ST600MM0026 SAS3 10K 600GB Hard Drives (Main Array)
• 2x Intel Pro 2500 SSD (for Hyper-V OS and some SSD L2 Cache)
• Direct Connect Backplane
• 2x LSI 9207-8i HBA
• 1x Intel X710DA2 10GbE Dual Port Network Adapter for Storage Network
• 2x Intel i350T Dual Port 1GbE Network Adapters (1, integrated, 1 option card) for Production and Management Network
• StarWind vSAN Standard
I have the 2x SSD, rear mounted and mirrored for the W2K12R2 OS and for L2 Cache for StarWind
I have the 16x SAS drives in a single Storage Pool and I have created two Windows Storage Spaces virtual disks of about 2TB each. These virtual disks are called CSV1 and CSV2
I have direct connect Twinax patch cables to connect the two servers, one for each 10GbE Port.
I set up VLANS on each 10GbE port as follows;
• Server 1, Port 1 - SYNC1vLAN at 172.21.110.1 - Connects to Server 2, Port 1, IP 172.21.110.2
• Server 1, Port 1 - iSCSI1vLAN at 172.21.210.1 - Connects to Server 2, Port 1, IP 172.21.210.2
• Server 1, Port 2 - SYNC2vLAN at 172.21.111.1 - Connects to Server 2, Port 1, IP 172.21.111.2
• Server 1, Port 2 - iSCSI2vLAN at 172.21.211.1 - Connects to Server 2, Port 1, IP 172.21.211.2
I ran iPERF on all 4 IP sets of the 10GbE cards and got 9.7Gb/s for Port 1 and 9.37Gb/s on Port 2
I then set up StarWind on Server 1 with a 1g virtual hard drive for the Witness device and a 2TB virtual hard drive for the CSV1 device.
After setting up the 2TB virtual hard drive, I launched Replication Manager and added a replica of CSV1 on Server 2, specifying the VLAN IP addresses. This is where I noticed the first issue. It took 5 hours and 40 minutes to create the replica.
I ran IOMeter on the Server1 CSV (Storage Spaces) from Server 1 and got around 5K IOPS at 100ms with 32 threads, 16 Outstanding I/Os, running tests to simulate SQL workload.
I ran IOMeter on the Server2 CSV (Storage Spaces) from Server 2 and got around 4.9K IOPS at 109ms with 32 threads, 16 Outstanding I/Os, running tests to simulate SQL workload.
Using StarWind, I set up a 75GB RAMDisk device on Server 1 and then ran IOMeter on Server 1 targeting the RAMDisk, I got about 125K IOPsat 4ms with the same test and number of threads used above.
I then used the Windows iSCSI Initiator on Server 2 to connect to the StarWind RAMDisk on Server 1. I specified the Storage LAN IP addresses in the Discovery Portal area of the Discovery Tab in iSCSI Initiator. I then ran IOMeter from Server 2, targeting the RAMDisk from Server 1 using the same number of threads and tests as above. In this test, I only got about 50K IOPS at 200ms. I watched the Resource Monitor on Server 2 and I was only seeing traffic on the iSCSI1vLAN and well below 50% utilization.
So, I seem to be having a problem getting the Intel X710DA2 10GbE adapters to use multipath with iSCSI to give me the performance I am expecting. I am not sure if this is an issue with StarWind or the Intel 10GbE Adapters.
I need help to verify that I have iSCSI set up properly for the Intel adapters so that they use multipath.
Any suggestions or ideas would be greatly appreciated.
Thanks in advance,
Dave
darklight
Fri Jun 26, 2015 10:36 am
Hi dcadler.
Do you have jumbo packet (jumbo frames) enabled on all of your iSCSI and Sync networks?
dcadler
Fri Jun 26, 2015 4:45 pm
Yes, Enabled at 4088 Bytes
darklight
Wed Jul 01, 2015 11:07 am
Should be 9000 and over depending on NIC vendor and OS you are using.
Vladislav (Staff)
Mon Jul 06, 2015 3:44 pm
Just wondering if the issue was resolved
dcadler
Mon Jul 06, 2015 8:55 pm
We had a StarWind engineer to a remote connection to the server and he discovered that the issue was in the underlying array data transfer speed. Using an IOMeter test of 64K Block, 100% write, 100% Sequential, 16 outstanding I/Os and 32 Workers, the resultant throughput showed that it would barely push ~1Gb/s sync speed.
I ran the same tests myself IOMeter test with StarWind completely removed and got similar results.
I have since replaced once of the LSI 9207-8i HBAs with an LSI 9260-8i with 512MB on-board cache and configured eight of my 10K SAS drives in a RAID 10 array. I completely deleted Windows Storage Spaces. I also enabled the write-back cache in the LSI controller. I have not re-installed StarWind yet but the same IOMeter test on the server that was used initially by the StarWind engineer is now giving me a calculated 21,728 Gb/s of throughput.
My conclusion is that, at least for sequential write operations needed for the StarWind replication, Windows Storage Spaces is not up for the job.
I have ordered additional controllers and will report back with the actual replication results once I get the second server configured with hardware RAID 10.
Dave
Vladislav (Staff)
Wed Jul 08, 2015 3:00 pm
Oh, it was me :)
I remember. Glad to hear it again!
dcadler
Wed Jul 08, 2015 4:25 pm
@Vitaliq - I was just wondering... do you think that a pair of servers with the underlying Windows Storage Spaces drive array 64K sequential write speeds of 140MB/s, like the ones you remoted into and tested, would even be capable of functional StarWind replication performance for the StarWind vSAN Standard version with up to 4TB of replicated CSVs?
Vladislav (Staff)
Mon Jul 13, 2015 2:36 pm
Sure, why not. StarWind does not care how fast an underlying storage is. It utilizes all possible resources to ensure maximum possible performance.
But please note, that Cluster Validation won't be possible by default on top of Storage Spaces.
https://knowledgebase.starwindsoftware. ... ge-spaces/
Branin
Mon Jul 13, 2015 11:30 pm
dcadler wrote: <snip>
<snip>
The recommendation from https://knowledgebase.starwindsoftware. ... s-replica/ is to create small virtual drives, then extend them after the replication is complete. This is what I do and my initial replications are only a few seconds (and the extensions out to multiple terabytes are also only a few seconds).
Branin
darklight
Mon Jul 20, 2015 9:21 am
I believe the guys from StarWind should add this trick into Management Console, since it's really not obvious but saves a lot of time sometimes.
Vladislav (Staff)
Mon Jul 27, 2015 2:26 pm
Hey darklight,
What do you expect to see in the console?
