read-only mount a same image file
Locked
Tom-N
Sat Jul 02, 2005 4:10 am
Can two or more machine read-only mount a same image file?
If so, how should I describe it in the configuration file?
I use StarWind ver.2.6.1.
Val (staff)
Sat Jul 02, 2005 8:17 pm
Tom-N wrote:Hello,
Hi Tom,
To allow the mode you need to edit the config file manually and then restart the StarWindService.
Use the following syntax to allow 2 simulteneous redonly sessions:
add ImageFile0 -file:"test.img" -readonly:"yes" -share:"r" -sessions:2
Valeriy
Tom-N
Fri Jul 08, 2005 6:10 pm
Thank you!
Val (staff)
Fri Jul 08, 2005 8:53 pm
Tom-N wrote:Thank you!
I'm glad it works for you.
Valeriy
Locked
