I am setting up a small lab environment using virtual san v8 on an older Dell 2950 with Perc 5i to be used as my iSCSI target. I will be using the new LSFS file system with L2 cache on an SSD with de duplication, thin provisioned.
The server will present iSCSI to an ESXi host with various VM workloads.
My 2950 has a Perc 5i controller on it and I have 6 x 450gb SAS drives. I read about the benefits of LSFS and am struggling to understand the settings on my raid controller that would result in the best results for performance.
I am thinking of running RAID5 on the controller, it appears write back cache is a good option for the write cache, but not sure about read cache. Does LSFS take advantage of read ahead cache or not? My option are read ahead, adaptive read ahead, and disabled.
Also, there is mention of stripe sector size, with option from 8k up to 128k. Reading online, it seems LSFS dedupe block sizes are 4k, so not sure what I should set this to? Any recommendations?
Thank for the help.
