Missing my Network Adapters
joshwilliam
Sun Mar 29, 2015 2:22 am
I am having an issue connecting 2 nodes. I have setup the servers and targets. I think the issue may the I only have the localhost loopback network adapter in Settings. When I click add I can see the other network cards. When I select one and click OK, nothing happens and I never see the Nic show up. I am hoping someone knows of fix for this.
Josh
Vladislav (Staff)
Tue Mar 31, 2015 11:59 am
Hi Josh,
It might happened if port 3260 already reserved. If MS iSCSI target is installed, then it is definitely the cause.
