7774 not compatible with vSphere 6
BillMoller
Fri Mar 20, 2015 1:29 am
Will there be an interim build, or will the new VM appliance features be added first?
~Bill
Fri Mar 20, 2015 12:16 pm
If you mean VSAN deployment then currently 5.5 should work and for 6.0 you'd better perform manual installation of StarWind service inside VMs. VMware had changed APIs a bit sorry about that :)
Our next stage would be providing pre-packaged VMs with StarWind Service pre-configured inside. We'll continue both new OVF and exiting deployment way (StarWind would be updated for vSphere 6.0 soon).
BillMoller wrote:Will there be an interim build, or will the new VM appliance features be added first?
~Bill
BillMoller
Wed Mar 25, 2015 12:39 am
Excellent, thank you. OVF deploy will be great.
~Bill
Fri Mar 27, 2015 10:42 am
We are glad that it helped. We`ll do our best to keep community tuned.
dsellens
Fri Jun 12, 2015 11:19 pm
Doesn't look like 8116 is compatible either. I just wasted 3 hours trying to get 7774, then 8116 to work because it isn't documented on the website.
Jhon_Smith
Wed Jun 17, 2015 5:38 pm
So did you actually manage to get it working?
dsellens
Thu Jun 25, 2015 7:16 pm
I haven't, still waiting on next update. When will that be folks? I really need 6.0 support.
Oles (staff)
Fri Jun 26, 2015 11:52 am
Unfortunately we have no ETA yet. As soon as it will be determined, i will provide you with update. Thank you for your patience.
