Snapshotting Schedule
robc
Wed Mar 04, 2015 4:13 pm
I am after scheduling the snapshoting on each device to happen one a day and keep the previous 5 snapshots.
I really expected there to be a simple way to achieve this but I cant seem to find it.
I did have a go at powershell but it was not happening for me.
I go to:
$server.Connect()
if ( $server.Connected )
  #Enter code here
    $server.Disconnect()
But then I try to add the new-snapshot cmdlett I just get an error: The property 'Connected' cannot be found on this object.
Can anyone recommend a way of doing this by schedule?
Tarass (Staff)
Fri Mar 06, 2015 5:17 pm
Hi Rob,
Please make sure you have the latest StarWind build installed. I have uploaded a draft of snapshot rotation document and the script to be used with it.
Read it carefully and try again. Let me know if it does not work.
StarWind Software Inc.
