IP Change from Clusterservers
zolloz
Fri Feb 06, 2015 10:59 am
we have a Windows 2012 Cluster with 2 Server and starwind native san V6.0.6399. We would like to change the ip address/subnet from each server. is that possible? what should we do?
Thanks for help.
Wed Feb 11, 2015 12:20 pm
Yes, it is possible. The safest and easiest way to do that is presented in v8. Please let me know if you will update to it and I will provide you with instructions.
zolloz
Mon Feb 16, 2015 9:21 am
At the moment we won't change the Version. How can we do this in V6? Do you have an instruction guid?
Fri Feb 20, 2015 12:41 pm
In v6 You need to bring one of the HA mirrors down (remove it), add it back, and specify the new IPs in the device creation wizard.
