The device, \Device\Harddisk1\DR1, has a bad block.
pfeifferl
Wed Dec 17, 2014 7:57 am
We use current V8 build 7471.
In the Server Log there is a huge amount of these entries:
12/17 8:18:23.961 a48 IMG: *** ImageFile_Dispatch_Unmap: ImageFile_ExecuteFileLevelTrim( 480871840, 1008 ) failed, status == 0xC0000001!
12/17 8:18:23.961 a48 IMG: *** ImageFile_ExecuteFileLevelTrim: ExecuteFileLevelTrim: GetOverlappedResult() after FSCTL_FILE_LEVEL_TRIM failed (err 50).
On initiator side (Win 2012 R2, MS iSCSI initiator) the system event log is full of: Disk - Event ID 7: "The device, \Device\Harddisk1\DR1, has a bad block."
It's the first time we have these troubles with starwind - I think it's because of the newest release ...
Release Notes V8 build 7471 (11 December 2014)
Fixes and updates in this build:
Fixed processing for UNMAP/TRIM commands. Virtual device was failing in cases when underlying storage doesn't support UNMAP/TRIM commands, but client use these commands to manage storage.
With 7354 we had no troubles ...
Thanx for any help!
regards,
Lukas
Fri Dec 19, 2014 10:22 am
Looks like UNMAP command issue. We are already fixing it and expecting the fix to be included in the next minor update. Stay tuned.
pfeifferl
Fri Dec 19, 2014 10:30 am
ok, thanx. I think we should downgrade to build 7354, which works ...
Fri Dec 19, 2014 6:14 pm
Well, I`d do that as well.
javasdk
Mon Mar 16, 2015 3:30 pm
I have usgin build 7774 also have this problem.
I have connected 4 LUN but only one LUN report bad block :roll:
Thu Mar 19, 2015 9:36 pm
Quick question:
What StarWind disk sector size are you using please?
javasdk
Sat Mar 21, 2015 6:09 pm
i am using 4k disk
Mon Mar 23, 2015 7:10 pm
Can you try 512 please?
javasdk
Thu Mar 26, 2015 1:20 pm
any easy method to convert 4k to 512?
or i need to create the new image?
Fri Mar 27, 2015 11:09 am
That requires recreating whole image
