Completed the setup outlined in: http://www.starwindsoftware.com/styles- ... Sphere.pdf
I have an HA volume setup between the two Starwind Controller VMs that is 1TB in size. Jumbo frames are turned on within the NICs of the two Starwind Controllers VMs for SYNC, iSCSI and iSCSI local as well as the ESXi Host VMkernel ports used for iSCSI Communications. Jumbo frames have been enabled on the Cisco 2960 connecting these hosts. All SYNC and iSCSI communications happen on the Intel NICs. The Broadcom nics are only used for VM and Management traffic.
Underlying hardware for each host:
1 x Dell 2950s - 16GB RAM / 2 x Intel(R) Xeon(R) CPU E5405 @ 2.00GHz
2 x Broadcom Corporation Broadcom NetXtreme II BCM5708 1000Base-T
2 x Intel Corporation 82571EB Gigabit Ethernet Controller
8 x 1TB SATA 7200RPM (In RAID-10 Configuration)
Running VMware ESXi 5.5 Update 2
HA Datastore is Thick Provisioned
iSCSI Paths in VMware are set as Fixed paths with the local_iSCSI (Internal only vSwitch) set as the preferred* with the non internal as backup.
I completed an IOMeter test on a Win Server 2012 R2 machine running as the Starwind Controller VM (4K 100%read) and got about 23000 IOPS @ 96Mbytes/sec, .67sec average response time, 34sec max response time - This volume is the one used to store the starwind HA volumes.
I completed a second IOMeter test on a Win Server 2012 R2 machine running on the HA data store (4K 100%read) and got about 3000 IOPS @ 12.25 Mbytes/sec, 5.34 average response time, 94.6sec max response time
Using net perf I found the Starwind Controller VMs can communicate with eachother at a full 1000Mbit/sec over their network connections used for SYNC and iSCSI comms. Unsure of the speed between the VMs and the vmKernel Ports but I'm assuming its the same.
Am I missing something or should the speed be better on the VM running within the HA Datastore? Please let me know of whatever I can try to improve this performance. There is only 1 VM running on this HA Datastore and I fear as we add more the performance will continue to degrade...
Thanks in advance for any help and let me know if you have any questions with what I state above!
Jonathan VDZ
