How to deaktivate L2 Cache
ltb76
Thu Aug 28, 2014 3:33 pm
How do I deactivate L2 cache on an existing published image?
Is it just a matter of removing the "<caching> </caching>" section of the swdsk file?
And how do I make sure that all data is flushed?
Thank you in advance,
Lasse
robnicholson
Thu Aug 28, 2014 4:55 pm
Ohh, you're brave! ;-) True it's just an XML file but personally I'd remove the target & device and re-create using an existing device. Chances are editing the XML will end up at the same place. Of course, you'll have to disconnect any iSCSI targets first.
I believe being able to make edits like this via the GUI are on the roadmap. Hopefully live but that's a challenge in itself.
Cheers, Rob.
ltb76
Thu Aug 28, 2014 5:32 pm
robnicholson wrote:Ohh, you're brave! ;-) True it's just an XML file but personally I'd remove the target & device and re-create using an existing device. Chances are editing the XML will end up at the same place. Of course, you'll have to disconnect any iSCSI targets first.
Cheers, Rob.
That was my initial thought, but going the "re-create" route requires the L2 Cache disk to be mapped, and that way I will not get rid of it, so that is a no go.
In the help file they state you can change the size by shutting down the service and then change the size in the swdsk file, but they do not mention how I get rid of it entirely :(
Thu Sep 04, 2014 3:53 pm
Hi!
Looks like your question has been answered. Please let me know if you did what you wanted successfully.
