I've got my lab working with a 2-node HA and did the following:
1. Started a 3GB file copying from a test file server using an iSCSI connection to both nodes
2. Stopped the StarWind service on the second node
3. The file copy completed - yeah!
I've now restarted the service on the second node so obviously, it's out of sync.
The question: does the node have to completely resynchronise the disk or does it know which blocks are out of sync and will only re-sync that bit?
The question is really how long it takes for a node that was off-line for a short amount of time to come back up?
Cheers, Rob.
