StarWind iSCSI SAN
Starwind on SSD - Thin or thick provisioning better?
Pure software-based VM-centric and flash-friendly VM storage (iSCSI, SMB3, NFS, iSER and NVMe over Fabrics) including free version. Same software embedded on StarWind ready nodes.
Postby fanello » Thu May 08, 2014 1:53 pm
If I use starwind on SSDs, is it better to use thin or thick provisioning? What about the auto-defrag feature. Should I activate it with SSDs?
In my opinion thin provisioning should be quicker on SSDs because of TRIM. If I use thick provisioning the host doesn't see the free areas on the SSDs and can't trim it. Is this correct?
Regards
Benny
fanello
Re: Starwind on SSD - Thin or thick provisioning better?
Postby anton (staff) » Thu May 08, 2014 7:59 pm
Use LSFS with flash to accelerate writes, make flash life longer (reduced amount of writes and erase cycles) and increase capacity (usable) because of dedupe.
Postby fanello » Wed May 14, 2014 4:16 pm
Thanks for your reply. Should I activate the auto defrag feature?
fanello
Postby anton (staff) » Wed May 14, 2014 5:11 pm
YES
fanello wrote:Thanks for your reply. Should I activate the auto defrag feature?
Postby fbifido » Wed May 14, 2014 7:29 pm
fanello wrote:Hi,
Regards
Benny
on SSD, you will use LSFS (thin)
enable auto-defrag
enable dedup
I think that's what "anton" is saying !
BTW:
1) what size is your SSD?
2) What OS are you using?
3) Are u using windows dedup?
4) Are u using HD & SSD or just all SSD?
fbifido
Postby Anatoly (staff) » Thu May 15, 2014 2:12 pm
fbiofido reminded me few things that is worth for you to know:
1.Don`t use any other deduplication except StarWind. Having more then one DD running will ruin the DD effect.
2.Don`t use the thin provisioning on the VM level, otherwise they won`t dedup at all.
[email protected]
Postby barrysmoke » Tue Jun 10, 2014 5:02 am
can you elaborate on the thin provisioning at the vm level?
I would assume that the empty space on thin provisioned vm's wouldn't matter if the starwind dedup is block level?
I want my cake, and eat it too in other words :-)
barrysmoke
Postby anton (staff) » Tue Jun 10, 2014 8:02 am
VM space would be returned to StarWind LUN but StarWind should also take care of returning LUN space to host.
barrysmoke wrote:can you elaborate on the thin provisioning at the vm level?
Postby MichelZ » Thu Jun 12, 2014 5:36 pm
Is LSFS now out of "experimental" mode?
MichelZ
Postby anton (staff) » Thu Jun 12, 2014 9:31 pm
Yes, GOLD now. But like with ZFS we do update it all the time.
MichelZ wrote:Is LSFS now out of "experimental" mode?
Return to StarWind Virtual SAN / StarWind Virtual SAN Free / StarWind HyperConverged Appliance / StarWind Storage Appliance
Who is online
Users browsing this forum: Google [Bot] and 7 guests
