fanello
Thu May 08, 2014 1:23 pm
i've created a clustered storage and now I want to increase its cache size. Is it correct, to stop die Starwind service, than open the starwind.cfg file, and set CacheSizeMB="desired amount"?
Thanks for your help.
regards
Benny
Thu May 08, 2014 1:36 pm
For now cache is static so you need to stop service and change cache size. Upcoming versions (minor update after V8 release) will have dynamic cache.
fanello
Thu May 08, 2014 1:42 pm
I changed cache size in the cfg file, but starwind still showes 128MB of Cache.
I have created ClusteredStorage with the Starwind Cluster function.
I see some differences in the cfg FIle, if I create a device and than cluster it and direct creation of clustered storage.
If I create a device and then use replication Manager, the cfg shows: CacheSizeMB="15000" CacheBlockExpiryPeriodMS="5000"
With clustered Storage: CacheSizeMB="128" CacheBlockExpiryPeriodMS="0"
Do I also have to set "CacheBlockExpiryPeriodMS" if I increase the cache?
Regards
Benny
Bohdan (staff)
Thu May 08, 2014 7:20 pm
Did you restart StarWindService after editing the config file?
jcrowe
Sat May 10, 2014 1:27 am
anton (staff) wrote:For now cache is static so you need to stop service and change cache size. Upcoming versions (minor update after V8 release) will have dynamic cache.
Will this also include dynamic L2 cache?
Sat May 10, 2014 10:23 am
Yes, both.
jcrowe wrote:anton (staff) wrote:For now cache is static so you need to stop service and change cache size. Upcoming versions (minor update after V8 release) will have dynamic cache.
raymondjt
Sat May 24, 2014 6:15 am
Look at your "Edition"...
The free version has some known and some unknown limits.
I think the maximum cache size 128 mb is still in the free version.
If you have a "full version" then it could depend on old ha-images.
Even if you have have all features licensend, with old imgages you sometimes not able to use some new features.
Try a complete new image and look if the max cache size is still 128mb.
greetings from germany
Raymond
Sun May 25, 2014 9:40 am
We'll check it out if it's still there (occasionally) we'll flex it out. Thank you for bringing our attention on this!
raymondjt wrote:Look at your "Edition"...
Raymond
Fri Jun 13, 2014 12:03 pm
Early Fall 2014 (after VMworld in SF).
MichelZ wrote:Is there an ETA for the dynamic cache thing?
