High Availability StarWind iSCSI
johnnytan
Tue Apr 01, 2014 3:20 am
Hi, I would like to ask it is possible to do a 2-node failover webserver with HA iSCSI?
e.g.
I have 2 servers with StarWind installed and created a single 128GB HA iSCSI drive.
Then I have another 2 servers which will serve as webserver with MSSQL installed where the data will be saved and stored in the ISCSI drive.
1 of the server will be dormant as standby and will only run when the primary webserver is down.
I remember reading somewhere that iSCSI are to treat as a single 'hard disk' where they can't be plugged into 2 different server at the same time.
Tue Apr 01, 2014 11:25 am
I can confirm that this is possible!
Please do not hesitate to contact usshould you have any additional questions. It would be our pleasure to further assist you!
jtmroczek
Wed Apr 02, 2014 6:59 pm
A quick note: What you want to do is setup a MSSQL Failover Cluster. Just installing SQL on 2 servers and switching the disk back and forth will not work. Use the HA iSCSI disk(s) as your cluster disk(s).
http://technet.microsoft.com/en-us/libr ... 79530.aspx
~joe
Thu Apr 03, 2014 1:11 pm
Nice link! Thanks for sharing!
