I am in the process of setting up a SAN for my lab environment and was looking at startwind, but there are a couple things I am looking for and would like to know if starwind can do this.
1. Would like the ability to not need a raid controller, If I use independent disk, can I use starwind volumes in a raid configuration on those disk. I know I can use windows software raid but not sure what impact that will have on performance.
2. Can I configure starwind volumes so that if I need to grow the disk over time I can. (i.e I have 3 1TB disk I am planning on using, I would like the ability over time to replace 1 disk with a larger disk (3TB) and then grow the volume as all the disk are replaced.) Similar to how drobo's work.
3. I have an SSD drive that I would like to use to speed up disk access to the 1TB disk, is this possible?
I currently have a ZFS SAN setup but it is slow and looking to move away from that configuration. I will be using it to run virtual machines and I have found out that zfs is not good for running virtual machines unless you have tones of memory.
the hardware I have for this SAN is a 3 core phenom processor, 4gig of ram, quad port gigabit ethernet adapter, and 3 1-TB HDDs for new system. My old SAN has 3 1-TBB HDD, 1 128 SAS disk, and 120GIG SSD that will be moved to new SAN once storage is migrated.
