Hi all,
I have installed Starwind iSCSI SAN & NAS ond two servers. With the iSCSI Initiator i can connect to the second server, but not to the other server. In the EventViewer i see the following ID's:
Log Name: System
Source: iScsiPrt
Date: 2/10/2014 23:50:27
Event ID: 10
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: RDDC.FUTURE.local
Description:
Login request failed. The login response packet is given in the dump data.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="iScsiPrt" />
<EventID Qualifiers="49152">10</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2014-02-10T22:50:27.698508000Z" />
<EventRecordID>20388</EventRecordID>
<Channel>System</Channel>
<Computer>RDDC.FUTURE.local</Computer>
<Security />
</System>
<EventData>
<Data>\Device\RaidPort1</Data>
<Binary>0000900001000000000000000A0000C0000000000000000000000000000000000000000000000000230000000000000040000137000000000000000100000000000000000000000000000000030100000000000000000000690071006E002E0032003000300038002D00300038002E0063006F006D002E007300740061007200770069006E00640073006F006600740077006100720065003A003100320037002E0030002E0030002E0031002D006E006F00640065003100</Binary>
</EventData>
</Event>
Log Name: System
Source: iScsiPrt
Date: 2/10/2014 23:51:17
Event ID: 1
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
Initiator failed to connect to the target. Target IP address and TCP Port number are given in dump data.
Event Xml:
<System>
<EventID Qualifiers="49152">1</EventID>
<Level>2</Level>
<Task>0</Task>
<TimeCreated SystemTime="2014-02-10T22:51:17.083118100Z" />
<EventRecordID>20390</EventRecordID>
<Security />
</System>
<EventData>
<Binary>000006000100000000000000010000C0000000000000000000000000000000000000000000000000BC0C0A000001</Binary>
</EventData>
</Event>
I have disabled the Windows Firewall on all servers. Hoe can i fix this issue?
