Hello All!
I have just met with the StarWind software family but I have very good experience with it. Unfortunately, I have a problem which I could not solve this far. If I create a HA device with an active-active Starwind cluster configuration I can see multiple devices on the Windows initiator side. That's not a problem because I can configure the MPIO driver in the Windows and after that I can see only one device. There is a really good detailed guide for it. That's working perfectly.
The problem is, when I trying to use the StarWind initiator, I am not able to set up the MPIO. So if I mount the disks over Native MS iSCSI initiator MPIO is working fine, but If I am using the StarWind initator the MPIO does not work.
Could you help me what did i miss?
Best Regards
Sanyi
