Hyper-V cluster setup Help ?
fbifido
Mon Sep 09, 2013 3:56 am
How would you setup this cluster ?
you can use VLANs
you can team nics
you can remove SW3 and use crossover cables
all surjections are welcome.
There is only a few rules:
1) Only the Management subnet or VLAN can access the physical machines and switches
2) the running vm are 2 only know about their virtual switches and the LAN (aka cloud)
3) The PC AD/DC is only for the nodes and storage, if the VM's need a DC, it will be a VM.
4) Try to limit the network traffic/congestion as mush as possible
5) use the color code below or more if needed
if the above image is not shown try this link http://i44.tinypic.com/14lofgg.png
CCI
Mon Sep 09, 2013 5:01 am
You may be able to pull some ideas from my setup. I have used this setup for many months now without issue:
I Virtualized all my AD/DCs
Diagram (Made with free Gliffy account)
http://www.gliffy.com/go/publish/4404348/
Powershell Code:
https://gist.github.com/ADABman/5178646 ... tfile1.ps1
Mon Sep 09, 2013 2:24 pm
Hi fbifido,
To be honest I`m pretty sure that CCI shared with us pretty good diagram to follow - I do can confirm that it looks great. Just don`t forget to follow our Best Practices guide lines that you can find by using this link.
fbifido
Tue Sep 10, 2013 2:41 am
CCI wrote:You may be able to pull some ideas from my setup. I have used this setup for many months now without issue:
Love that diagram, i did not know they had stuff like that online. Thanks.
But as you can see, am i not only using node hyper-v server, i am also using a storage server.
Thu Sep 12, 2013 9:37 am
I see that few data links are marked as "iSCSI + Sync", so they will be used as the IPs for client connections and the Synchronization channel at the same time? If yes, then I must warn you that it is highly recomended to to separate SyncChannel from everything else. Also, I want you to read through this document:
http://www.starwindsoftware.com/starwin ... ces-manual
