Version mismatch starwind management console
Piterskuy
Mon Sep 02, 2013 8:51 am
I try to install Starwind Software and make cluster at two Windows Server 2012.
The first attempt (1st server) was good, software installed without any problem I checked the Soft for Hyper-V.
The second was not good as first, I can't select the installation for Hyper-V software because of I can't see it.
After the installation when try to connect to my local host after typing the password I see this:
Uninstallation couldn't help me.
Mon Sep 02, 2013 4:08 pm
Hi!
May I doublecheck with you about what exactly product this screenshot is realted to (StarWind iSCSI SAN, Backu plug-in, V2V converter, etc)?
Piterskuy
Wed Sep 04, 2013 10:54 am
Sorry.
It was StarWind iSCSI SAN.
I solved this problem with total reinstall Windows Server 2012.
Wed Sep 04, 2013 1:07 pm
Wow, that was tuff :D
OK, so everything is working correctly?
Piterskuy
Wed Sep 04, 2013 1:12 pm
Wed Sep 04, 2013 1:44 pm
Well, we`ll do our best to get it running ASAP. As you can see I`ve already answerred there 8)
