Let me fill you in on what I thought I could do with Starport and Starwind Server. I have a laptop that I use primarily and want to burn some dvds off of various computers on my network. I have a pretty extensive setup with the following:
Xp 2000+ Desktop
Laptop Sony Vaio FX210
HTPC (Home Theater PC connected to a Mitsubishi 65 HD Set with a vga transcoder for image conversion)
Server: Win2k3
Xbox 1 and 2 on Lan
Dlink 624 Router - No previous issues at all, all xp firewalled disabled.
Etc.
I usually use RDP or VNC actually for specific reasons. When you use RDP you do not get the true resolution settings and graphic settings of that display. Using VNC overcomes this. It is crucial when working with home theater pcs because of the specific resolutions required to maintain sync and refresh rates. Powerstrip handles this task quite well. Since we use our HTPC to watch tv shows and movies, dvds upscaled, I want to do background tasks such as burning DVDs. So that brings me here thanks to a google search.
If you are still with me, this appears to be an amazing piece of software to allow you to share ide, usb, firewire, scsi devices over a lan. I have read the manuals extensively but am still coming back to the same issues over and over. Doesnt matter which machine its installed on. Starwind sets up fine and mounts the drive just fine. Star port connects to the drive just fine as well. Even shows up in My Computer. Then it starts.
No matter which application I chose:
Nero
Alchohol
RocketDivisions own Burning Software. They all hang at the splash screen every time. I have to do a hard boot. Not even taskmgr.exe will kill the processes. Isnt that wierd? Of course once it reboots finally after I cant take it anymore. I have to shut down starwind and restart the service just to get it to reconnect from the client side (*starport)
Any help here would be greatly appreciated. .
For what its worth, Im using an NEC 2500A drive when im attempting to set this up. Am I correct that if set up properly , the drive should show up as an available device under the burning application? So many questions, not sure this is going to go anywhere. BTW, i am nc88keyz on aim if anyone thinks they can help. Im really good with computers, networking, and even troubleshooting but this one has me stumped.
I have several apps on the computers as well. Way too many to list.
To recap, all the burning apps just sit there. Nero minimizes to sys tray never to come back up, alchohol just freezes up with blank screen, I think its any authoring app that is trying to access the drive. BTW, I have the latest versions from the website on both apps. All this time, the starwind app remains ok as in its not crashing the pcs. Its definately on the client side. I would be willing to pay for a great app like this. Would like to see it in its glory though.
Thanks for all your time,
Heres to an amazing application.
Nc88keyz
Attached Below is my Log from one of the machines - Since they all do the same thing I figure it wont matter which one the log is from.
04:46:32 - Entering func: CLanguager::LoadLanguage(language=0x409)
04:46:32 - Exiting func: CLanguager::LoadLanguage(language=0x409)
04:46:32 - CStarPortApp::CheckLicense: License data not found.
04:46:32 - CStarPortApp::CheckLicense: *** TRIAL VERSION *** [ expires in 15 day(s) ]
05:12:57 - Entering func: CStarPortAPI::CStarPortAPI()
05:12:57 - Entering func: CStarPortAPI::DriverOpen()
05:12:57 - Exiting func: CStarPortAPI::DriverOpen()
05:12:57 - Entering func: CStarPortAPI::DriverVersion(...)
05:12:57 - CStarPortAPI::DriverVersion: Calling STARPORT_IOCTL_GET_VERSION
05:12:57 - CStarPortAPI::DriverVersion: Input buffer:
05:12:57 - CStarPortAPI::DriverVersion: Signature = 72417453:
05:12:57 - CStarPortAPI::DriverVersion: ApiVersion = 20002:
05:12:57 - CStarPortAPI::DriverVersion: Calling DeviceIoControl(...)
05:12:57 - CStarPortAPI::DriverVersion: DeviceIoControl(...) called successfully
05:12:57 - CStarPortAPI::DriverVersion: Output buffer:
05:12:57 - CStarPortAPI::DriverVersion: Signature = 52615473
05:12:57 - CStarPortAPI::DriverVersion: Version = 20050310
05:12:57 - CStarPortAPI::DriverVersion: Flags = 0
05:12:57 - Exiting func: CStarPortAPI::DriverVersion(...)
05:12:57 - CStarPortAPI::CStarPortAPI: StarPort version: 20050310; StarPort driver: API v20002, Build 0x20050310
05:12:57 - Exiting func: CStarPortAPI::CStarPortAPI()
05:12:57 - Entering func: CDriveLetterMap::CDriveLetterMap()
05:12:57 - Entering func: CDriveLetterMap::Refresh()
05:12:58 - Exiting func: CDriveLetterMap::Refresh()
05:12:58 - Exiting func: CDriveLetterMap::CDriveLetterMap()
05:12:58 - Entering func: CStarPortDoc::CStarPortDoc()
05:12:58 - Exiting func: CStarPortDoc::CStarPortDoc()
05:12:58 - CMainFrame::OnCreate: Minimizing application to tray.
05:12:58 - Entering func: CStarPortView::OnInitialUpdate()
05:12:58 - Entering func: CStarPortDoc::ResyncRegistryAndDriverContents(bAutomountDevices=1)
05:12:58 - Entering func: CDriveLetterMap::Refresh()
05:12:58 - CStarPortDoc::ResyncRegistryAndDriverContents: Resyncronizing contents...
05:12:58 - Entering func: CStarPortAPI::GetDevices(...)
05:12:58 - CStarPortAPI::GetDevices: Calling STARPORT_IOCTL_TARGET_LIST
05:12:58 - CStarPortAPI::GetDevices: Input buffer:
05:12:58 - CStarPortAPI::GetDevices: Signature = 72417453
05:12:58 - CStarPortAPI::GetDevices: Calling DeviceIoControl(...)
05:12:58 - CStarPortAPI::GetDevices: DeviceIoControl(...) called successfully
05:12:58 - CStarPortAPI::GetDevices: Output buffer:
05:12:58 - CStarPortAPI::GetDevices: Signature = 52615473
05:12:58 - CStarPortAPI::GetDevices: NumberOfTargets = 0
05:12:58 - Exiting func: CStarPortAPI::GetDevices(...)
05:12:58 - Entering func: CStarPortAPI::InsertiSCSIDevice(dwIPAddress=0xC0A80204, dwPort=3260, szInitiaotrName=iqn.2003-06.com.rocketdivision.starport:xp2000, szTargetName=nec, szAdditionalParameter=, nTargetID=...)
05:12:58 - CStarPortAPI::InsertiSCSIDevice: Calling STARPORT_IOCTL_TARGET_MOUNT
05:12:58 - CStarPortAPI::InsertiSCSIDevice: Input buffer:
05:12:58 - CStarPortAPI::InsertiSCSIDevice: Signature = 72417453
05:12:58 - CStarPortAPI::InsertiSCSIDevice: Flags = 0
05:12:58 - CStarPortAPI::InsertiSCSIDevice: ServerAddress = 192.168.2.4:3260
05:12:58 - CStarPortAPI::InsertiSCSIDevice: Parameter[0] = InitiatorName=iqn.2003-06.com.rocketdivision.starport:xp2000
05:12:58 - CStarPortAPI::InsertiSCSIDevice: Parameter[1] = TargetName=nec
05:12:58 - CStarPortAPI::InsertiSCSIDevice: Calling DeviceIoControl(...)
05:12:58 - CStarPortAPI::InsertiSCSIDevice: Session failed, status == 1326 !
05:12:58 - Exiting func: CStarPortAPI::InsertiSCSIDevice(dwIPAddress=0xC0A80204, dwPort=3260, szInitiaotrName=iqn.2003-06.com.rocketdivision.starport:xp2000, szTargetName=nec, szAdditionalParameter=, nTargetID=...)
05:12:58 - CStarPortDoc::ResyncRegistryAndDriverContents: Exception caught: Logon to the server failed.
05:12:58 - Exiting func: CStarPortDoc::ResyncRegistryAndDriverContents(bAutomountDevices=1)
05:12:58 - Exiting func: CStarPortView::OnInitialUpdate()
05:13:10 - CMainFrame::OnCmdMsg: Enabling a command with ID=45000
05:13:12 - Entering func: CDriveLetterMap::~CDriveLetterMap()
05:13:12 - Exiting func: CDriveLetterMap::~CDriveLetterMap()
05:13:12 - Entering func: CStarPortAPI::~CStarPortAPI()
05:13:12 - Exiting func: CStarPortAPI::~CStarPortAPI()
Machine 2: Laptop AMD Athon4 1200MHZ *What the heck, Another log wont hurt. Heres to maybe the longest post to date
05:06:46 - Entering func: CLanguager::LoadLanguage(language=0x409)
05:06:46 - Exiting func: CLanguager::LoadLanguage(language=0x409)
05:06:46 - CStarPortApp::CheckLicense: License data not found.
05:06:46 - CStarPortApp::CheckLicense: *** TRIAL VERSION *** [ expires in 14 day(s) ]
05:07:08 - Entering func: CStarPortAPI::CStarPortAPI()
05:07:08 - Entering func: CStarPortAPI::DriverOpen()
05:07:08 - Exiting func: CStarPortAPI::DriverOpen()
05:07:08 - Entering func: CStarPortAPI::DriverVersion(...)
05:07:08 - CStarPortAPI::DriverVersion: Calling STARPORT_IOCTL_GET_VERSION
05:07:08 - CStarPortAPI::DriverVersion: Input buffer:
05:07:08 - CStarPortAPI::DriverVersion: Signature = 72417453:
05:07:08 - CStarPortAPI::DriverVersion: ApiVersion = 20002:
05:07:08 - CStarPortAPI::DriverVersion: Calling DeviceIoControl(...)
05:07:08 - CStarPortAPI::DriverVersion: DeviceIoControl(...) called successfully
05:07:08 - CStarPortAPI::DriverVersion: Output buffer:
05:07:08 - CStarPortAPI::DriverVersion: Signature = 52615473
05:07:08 - CStarPortAPI::DriverVersion: Version = 20050310
05:07:08 - CStarPortAPI::DriverVersion: Flags = 0
05:07:08 - Exiting func: CStarPortAPI::DriverVersion(...)
05:07:08 - CStarPortAPI::CStarPortAPI: StarPort version: 20050310; StarPort driver: API v20002, Build 0x20050310
05:07:08 - Exiting func: CStarPortAPI::CStarPortAPI()
05:07:08 - Entering func: CDriveLetterMap::CDriveLetterMap()
05:07:08 - Entering func: CDriveLetterMap::Refresh()
05:07:10 - Exiting func: CDriveLetterMap::Refresh()
05:07:10 - Exiting func: CDriveLetterMap::CDriveLetterMap()
05:07:10 - Entering func: CStarPortDoc::CStarPortDoc()
05:07:10 - Exiting func: CStarPortDoc::CStarPortDoc()
05:07:10 - CMainFrame::OnCreate: Minimizing application to tray.
05:07:11 - Entering func: CStarPortView::OnInitialUpdate()
05:07:11 - Entering func: CStarPortDoc::ResyncRegistryAndDriverContents(bAutomountDevices=1)
05:07:11 - Entering func: CDriveLetterMap::Refresh()
05:07:11 - Exiting func: CDriveLetterMap::Refresh()
05:07:11 - CStarPortDoc::ResyncRegistryAndDriverContents: Resyncronizing contents...
05:07:11 - Entering func: CStarPortAPI::GetDevices(...)
05:07:11 - CStarPortAPI::GetDevices: Calling STARPORT_IOCTL_TARGET_LIST
05:07:11 - CStarPortAPI::GetDevices: Input buffer:
05:07:11 - CStarPortAPI::GetDevices: Signature = 72417453
05:07:11 - CStarPortAPI::GetDevices: Calling DeviceIoControl(...)
05:07:11 - CStarPortAPI::GetDevices: DeviceIoControl(...) called successfully
05:07:11 - CStarPortAPI::GetDevices: Output buffer:
05:07:11 - CStarPortAPI::GetDevices: Signature = 52615473
05:07:11 - CStarPortAPI::GetDevices: NumberOfTargets = 0
05:07:11 - Exiting func: CStarPortAPI::GetDevices(...)
05:07:11 - Entering func: CStarPortAPI::InsertiSCSIDevice(dwIPAddress=0xC0A80204, dwPort=3260, szInitiaotrName=iqn.2003-06.com.rocketdivision.starport:fx210, szTargetName=nec2500, szAdditionalParameter=, nTargetID=...)
05:07:11 - CStarPortAPI::InsertiSCSIDevice: Calling STARPORT_IOCTL_TARGET_MOUNT
05:07:11 - CStarPortAPI::InsertiSCSIDevice: Input buffer:
05:07:11 - CStarPortAPI::InsertiSCSIDevice: Signature = 72417453
05:07:11 - CStarPortAPI::InsertiSCSIDevice: Flags = 0
05:07:11 - CStarPortAPI::InsertiSCSIDevice: ServerAddress = 192.168.2.4:3260
05:07:11 - CStarPortAPI::InsertiSCSIDevice: Parameter[0] = InitiatorName=iqn.2003-06.com.rocketdivision.starport:fx210
05:07:11 - CStarPortAPI::InsertiSCSIDevice: Parameter[1] = TargetName=nec2500
05:07:11 - CStarPortAPI::InsertiSCSIDevice: Calling DeviceIoControl(...)
05:07:11 - CStarPortAPI::InsertiSCSIDevice: Session failed, status == 1232 !
05:07:11 - Exiting func: CStarPortAPI::InsertiSCSIDevice(dwIPAddress=0xC0A80204, dwPort=3260, szInitiaotrName=iqn.2003-06.com.rocketdivision.starport:fx210, szTargetName=nec2500, szAdditionalParameter=, nTargetID=...)
05:07:11 - CStarPortDoc::ResyncRegistryAndDriverContents: Exception caught: The network location cannot be reached. For information about network troubleshooting, see Windows Help.
05:07:12 - Exiting func: CStarPortDoc::ResyncRegistryAndDriverContents(bAutomountDevices=1)
05:07:12 - Exiting func: CStarPortView::OnInitialUpdate()
