I have the Starwind iSCSI target running and configured on a Windodws 2012 server (physical machine.) I have the Microsoft iSCSI initiator running on a separate Windows 2012 server (Hyper-V VM on a different physical server.) Last week I successfully connected to the target and ran a backup to the iSCSI target. When I returned this week the connection to the target has been lost and I can't get it back. Last week I did setup a connection between the two servers using a dedicated backup VLAN, but I can ping both servers using the VLAN network. I can also see the portal from the initiator but no targets are available. I've removed all CHAP information to make sure it is not an authentication issue but that hasn't changed anything. I'm getting the following errors on the initiator side:
Log Name: System
Source: MSiSCSI
Date: 7/17/2013 7:22:43 AM
Event ID: 113
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Computer: DPMVM.internal.com
Description:
iSCSI discovery via SendTargets failed with error code 0xefff0003 to target portal *172.24.18.2 0003260 ROOT\ISCSIPRT\0000_0 .
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="MSiSCSI" />
<EventID Qualifiers="0">113</EventID>
<Level>3</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2013-07-17T12:22:43.000000000Z" />
<EventRecordID>6709</EventRecordID>
<Channel>System</Channel>
<Computer>DPMVM.internal.com</Computer>
<Security />
</System>
<EventData>
<Data>0xefff0003</Data>
<Data>*172.24.18.2 0003260 ROOT\ISCSIPRT\0000_0 </Data>
</EventData>
</Event>
Log Name: System
Source: iScsiPrt
Event ID: 1
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
Initiator failed to connect to the target. Target IP address and TCP Port number are given in dump data.
Event Xml:
<System>
<Provider Name="iScsiPrt" />
<EventID Qualifiers="49152">1</EventID>
<Level>2</Level>
<Task>0</Task>
<TimeCreated SystemTime="2013-07-17T12:22:43.934935900Z" />
<EventRecordID>6710</EventRecordID>
<Security />
</System>
<EventData>
<Data>\Device\RaidPort1</Data>
<Binary>000006000100000000000000010000C0000000000000000000000000000000000000000000000000BC0CAC181202</Binary>
</EventData>
</Event>
Log Name: System
Source: iScsiPrt
Event ID: 70
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
Error occurred when processing iSCSI logon request. The request was not retried. Error status is given in the dump data.
Event Xml:
<System>
<EventID Qualifiers="49152">70</EventID>
<Level>2</Level>
<Task>0</Task>
<EventRecordID>6711</EventRecordID>
<Security />
</System>
<EventData>
<Binary>000004000100000000000000460000C0000000000000000000000000000000000000000000000000360200C0</Binary>
</EventData>
</Event>
Any help would be appreciated.
Joe
