What type of disc should I choose?
f/x
Tue Jul 09, 2013 9:28 am
Hello, can you help me determine with technology.
When I try to create new disk I need a select the type of device... but I want use deduplication and CDP and etc in same time, as I can see it's not possible. In this case could you explain me which type for what? Unfortunately any yours documents contain information about particular technology and absolutely can't help decide me why I should use exactly this device or not another... I'm absolutely confused already in a lot of number abstraction layer.
Tue Jul 09, 2013 8:51 pm
If you want everything (snapshots, dedupe, CDP etc) in-wonder please wait for V8 beta scheduled this week and you'll end with eventual release in August 2013.
f/x wrote:Hello, can you help me determine with technology.
f/x
Wed Jul 10, 2013 12:41 am
This is perfect news! But I would like to understand the applicability of a particular technology on something indicative example. Please, If you are not hard... I think this will be very useful information for all of us...
Tnks
Ironwolf
Sat Jul 13, 2013 8:15 pm
Good news indeed
Will background CDP consolation be making an appearance?
As it is now, as snapshots expire, the underlining storage container remains in place as long as some of the data in the container remains valid data. This has an impact of rapidly filling disk space as remnants of old container files seem to stick around for very long times, instead of consolidating very old files. As it is now the only way to clean up the CDP files, is every few months copy the data out into another CDP volume. I moved to DD containers with delete enabled but this has its own limits as well, but does seem the closest thing to a build it and forget about it there is.
I would like to see a background service that works in a round robin fashion, and moves from one CDP to the next, until it cycles through all the CDP’s and then take a break for a week or a month and then starts again. As Starwind manages all the IO it could run it in the background, letting other IO activity have priority. Either by having the base CDP file purge expired data fragments and then merges in the valid fragments from expired CDP files. Or copy out valid data from the old base CDP file into a new base file and then merge in valid fragments form expired CDP files. Whichever makes the most Defrag sense inside of the base file should be used I would think (to many holes to plug, copy, only a few holes to plug, merge).
Otherwise for me CDP doesn’t have a valid reason to be used; it is just too much maintenance.
Thank you for a great product,
It is my hope the feedback is taken as constructive feedback and not a complaint in any way
Tue Jul 16, 2013 4:31 pm
Tnks
In short, you will be able to keep your data highly avaialble, you`ll get ability to recover in any point-in-time, even on the disaster recovery site, during your SSD will keep live longer while your RAID 5 will suddenly start showing you good read AND WRITE rates. I think this should give you the general idea of the concepts of next version. If this is not enough, maybe it is good idea to contact our sales dep and they`ll provide you with the required information specific to any potential project.
Actually this is how it should work starting from next version. Right now the deletion support is only experimental feature, which menas that it is highly not reommended to use it in the production environment.
We should have it in the next release as well.
Thank you for your feedback - it was constructive and really fluent. Only by knowing what people require we can determine where to move exactly! Thank you!
