2 node SAN for standalone Hyper-V hosts
jwillis84
Tue Jun 25, 2013 3:53 am
I'm looking for some clarification and advise regarding your products for creating a 2 node shared nothing SAN using two HP DL380p G8 servers for storage running WS2012 Standard.
We have 4 additional, separate servers, running Hyper-V 2012 to act as Hyper-V hosts.
I've read your Whitepaper "Configuring HA Storage for Live Migration on Windows Server 2012" and it appears to be the most suitable example of what we wish to achieve.
I was concerned that the instructions on Page 19 recommended using the MBR partition type. The HP DL380p servers currently have a 3.2 TB Volume each. If we use the MBR partition type I believe that will limit us to 2 TB. Can you confirm this, or suggest a workaround?
Also
You appear to have two products "StarWind iSCSI SAN & NAS" and "StarWind Native SAN for Hyper-V" which would be appropriate for our project?
I am not entirely certain, but thought "StarWind iSCSI SAN & NAS" would be the correct one to use.
However if we can achieve the same goals is "StarWind Native SAN for Hyper-V" a better choice?
Thank you
Tue Jun 25, 2013 10:14 am
Hi!,
The workaround is to use the GPT formatting instead - its absolutelly safe. Currently we are updating the document that you`ve mentioned.
The Native SAN has limitation on the servers that can connect to the HA devices: anything else will be able to connect to the HA drives, except the OSes where the StarWind is installed. As I see from your scenario the iSCSI SAN fits you best.
jwillis84
Tue Jun 25, 2013 1:24 pm
First,
Thank you for the quick reply.
Second, I just wanted to be sure that's GPT instead of some proprietary format I've never heard of called FPT. I can easily understand a typo from the position of the keys on the keyboard. But I wanted to make sure.
And is there an announcement forum or subcription method to receive notice when updated documents are issued?
Anatoly (staff) wrote:Hi!,
The qorkaround is to use the FPT formatting instead - its absolutelly safe. Currently we are updating the document that you`ve mentioned.
I also assume you mean .. "nothing else will be able to connect to the HA drives".. I had thought that might be the case.
If this is the case, describing it as a "embedded" or "localized SAN" to the Hyper-V hosts might be a more informative way to convey its usage model. Or a white paper example describing the use of this particualar product could be created. I might go as far as saying "its a SAN embedded within the nodes of a Hyper-V failover cluster which does not stand alone". Please correct me if I misunderstand the usage scenario.
In any event I am encouraged enough to begin trials.
Again thanks for the fast response.
Tue Jun 25, 2013 2:02 pm
You got me) Yes, I`ve misspelled GPT. Pobody is nerfect :D
Yes, that is exactly waht I`ve ment. And, yes, that is a good idea - we`ll definitelly try to use your idea.
Thank you
