Newbie needs a push start...
Locked
rhetoric
Tue Mar 08, 2005 4:00 am
Hello all!
I am trying to set up a Starwind/Starport relationship between two computers on my wireless network, the problem is I have no idea where to begin. I read through the guide that came with the Starwind application but I really did not understand any of it.
I want to share a DVD-R drive on one computer with one other machine on the network. The machine with the drive in question has Starwind installed and the computer that I want to be the client has Starport installed, but I cannot seem to get the two machines to connect. Any help would be appreciated, thanks!
rhetoric
Tue Mar 08, 2005 2:56 pm
ok.. so ive been working at it for a while and i got the server set and the client set, but when i try to connect to the Starwind target via the Starport initiator i get this: "the semaphore timeout period has expired"
is this a client side problem or is it a server side trouble? any help is appreciated.
Val (staff)
Tue Mar 08, 2005 3:21 pm
Hi rhetoric,
Do you use the correct IP address for the server machine in the StarPort's "Add device" dialog?
What are the machine's OSes?
If there is a WinXP SP2, so it has its firewall activated, so that the TCP/IP poart 3260 is disabled.
If you use any firewall you need to allow TCP/IP port 3260 to accept incoming connections (on the server machine) and allow the same port for outgoing connections (on the client one).
Valeriy
rhetoric
Tue Mar 08, 2005 3:46 pm
thanks for the reply,
yes, the client machine is XPSP2 and the port is open, but the server machine is XPSP1 so i dont know if the port is open or not. Is there a way to check this or is there automatically no firewall in SP1?
Val (staff)
Tue Mar 08, 2005 4:52 pm
rhetoric wrote:thanks for the reply,
WinXP SP1 has no embedded firewall, you are right.
You could use the EtherReal (or any other network sniffer software) to examine what's happening.
Valeriy
Locked
