VMWare Hosts See Starwind Target, Won't Map Datastore
dhudson
Mon Feb 04, 2013 6:27 pm
My vSphere 5.1 Hosts can see the Starwind target/path, but won't map the datastore. They can map my second Starwind target fine, however, so I don't suspect any problem with the hosts or their configuration.
Any suggestions, or does the following suggest a specific target config problem?
Thank you!
Log tail:
2/4 11:53:09.656 e54 Params: >>> DataSequenceInOrder=Yes.
2/4 11:53:09.657 cec T[57,1]: session 0x57, connection 0x57 : end of stage 1, next stage 3.
2/4 11:53:09.657 cec C[57], IN_LOGIN: Event - LOGIN_ACCEPT.
2/4 11:53:09.657 cec C[57], LIN: T5.
2/4 11:53:09.664 cec C[57], LIN: Event - LOGOUT.
2/4 11:53:09.664 cec C[57], IN_LOGOUT: T9/10.
2/4 11:53:09.664 1844 C[57], IN_LOGOUT: Event - LOGOUT_ACCEPT.
2/4 11:53:09.664 1844 C[57], FREE: T13.
2/4 11:53:09.664 e54 C[57], FREE: recvData returned 10054
2/4 11:53:09.666 904 Srv: Accepted iSCSI connection from 192.168.1.6:63188 to 192.168.1.11:3260. (Id = 0x58)
2/4 11:53:09.666 904 C[58], FREE: Event - CONNECTED.
2/4 11:53:09.666 904 C[58], XPT_UP: T3.
2/4 11:53:09.666 1a84 C[58], XPT_UP: Login request: ISID 0x00023d000000, TSIH 0x0000.
2/4 11:53:09.667 1a84 C[58], XPT_UP: Event - LOGIN.
2/4 11:53:09.667 1a84 C[58], IN_LOGIN: T4.
2/4 11:53:09.667 1a84 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:esxi3-2516acfd', accepted 'iqn.1998-01.com.vmware:esxi3-2516acfd'
2/4 11:53:09.667 1a84 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
2/4 11:53:09.667 1a84 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
2/4 11:53:09.667 1a84 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
2/4 11:53:09.667 1a84 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
2/4 11:53:09.667 1a84 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
2/4 11:53:09.667 1a84 Params: <<< Boolean param 'IFMarker': received No, accepted 0
2/4 11:53:09.667 1a84 Params: <<< Boolean param 'OFMarker': received No, accepted 0
2/4 11:53:09.667 1a84 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
2/4 11:53:09.667 1a84 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
2/4 11:53:09.667 1a84 Params: >>> ErrorRecoveryLevel=0.
2/4 11:53:09.667 1a84 Params: >>> HeaderDigest=None.
2/4 11:53:09.667 1a84 Params: >>> DataDigest=None.
2/4 11:53:09.667 1a84 Params: >>> OFMarker=No.
2/4 11:53:09.667 1a84 Params: >>> IFMarker=No.
2/4 11:53:09.667 1a84 Params: >>> InitialR2T=No.
2/4 11:53:09.667 1a84 Params: >>> ImmediateData=Yes.
2/4 11:53:09.667 1a84 Params: >>> MaxRecvDataSegmentLength=262144.
2/4 11:53:09.667 1a84 Params: >>> MaxBurstLength=262144.
2/4 11:53:09.667 1a84 Params: >>> FirstBurstLength=262144.
2/4 11:53:09.667 1a84 Params: >>> DefaultTime2Wait=0.
2/4 11:53:09.667 1a84 Params: >>> DefaultTime2Retain=0.
2/4 11:53:09.667 1a84 Params: >>> MaxOutstandingR2T=1.
2/4 11:53:09.667 1a84 Params: >>> DataPDUInOrder=Yes.
2/4 11:53:09.667 1a84 Params: >>> DataSequenceInOrder=Yes.
2/4 11:53:09.668 354 T[58,1]: session 0x58, connection 0x58 : end of stage 1, next stage 3.
2/4 11:53:09.668 354 C[58], IN_LOGIN: Event - LOGIN_ACCEPT.
2/4 11:53:09.668 354 C[58], LIN: T5.
2/4 11:53:09.675 354 C[58], LIN: Event - LOGOUT.
2/4 11:53:09.675 354 C[58], IN_LOGOUT: T9/10.
2/4 11:53:09.675 175c C[58], IN_LOGOUT: Event - LOGOUT_ACCEPT.
2/4 11:53:09.675 175c C[58], FREE: T13.
2/4 11:53:09.675 1a84 C[58], FREE: recvData returned 10054
2/4 11:53:36.833 1260 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb0 is not supported!
2/4 11:53:41.899 1260 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb0 is not supported!
2/4 11:53:46.217 1260 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb0 is not supported!
2/4 11:56:21.482 1260 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb0 is not supported!
2/4 11:58:36.824 1260 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb0 is not supported!
2/4 11:58:41.878 1260 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb0 is not supported!
2/4 11:58:46.211 1260 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb0 is not supported!
2/4 12:01:21.456 1260 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb0 is not supported!
Wed Feb 06, 2013 2:18 pm
Will you be so kind to doublecheck ig you have configured everything according to the official manual that you can find by using the link below?
http://www.starwindsoftware.com/images/ ... ere_v6.pdf
