New user help: Stuck at Windows 7 loading screen
kevinwan
Mon Dec 10, 2012 9:15 am
I was trying to boot off Windows 7 image from a Windows Server 2008 R2 using a guide from Windows Disksless
Apparently everything went smoothly until the first initial booting into windows screen when it got stuck. I took a look at the log from Starwind management console and have attached the log message.
12/10 16:52:48.615 ce0 Srv: Accepted iSCSI connection from 192.168.2.210:36374 to 192.168.2.200:3260. (Id = 0x8)
12/10 16:52:48.615 ce0 C[8], FREE: Event - CONNECTED.
12/10 16:52:48.615 ce0 C[8], XPT_UP: T3.
12/10 16:52:48.630 e48 C[8], XPT_UP: Login request: ISID 0x40002723558b, TSIH 0x0000.
12/10 16:52:48.630 e48 C[8], XPT_UP: Event - LOGIN.
12/10 16:52:48.630 e48 C[8], IN_LOGIN: T4.
12/10 16:52:48.833 e48 Params: <<< String param 'InitiatorName': received 'iqn.2010-04.org.ipxe:2175f081-49a5-11cb-a09d-9ed9bcb66a32', accepted 'iqn.2010-04.org.ipxe:2175f081-49a5-11cb-a09d-9ed9bcb6
a32'
12/10 16:52:48.833 e48 Params: <<< String param 'TargetName': received 'iqn.2012-12.com.demo.spl.com:win7', accepted 'iqn.2012-12.com.demo.spl.com:win7'
12/10 16:52:48.833 e48 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
12/10 16:52:48.833 e48 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
12/10 16:52:48.833 e48 Tgt: open 'iqn.2012-12.com.demo.spl.com:win7': 1 session(s) opened, 0 more allowed.
12/10 16:52:48.833 e48 Params: >>> AuthMethod=None.
12/10 16:52:48.833 e48 Params: >>> TargetAlias=W7.
12/10 16:52:48.833 e48 Params: >>> TargetPortalGroupTag=1.
12/10 16:52:48.833 90c T[8,1]: session 0x8, connection 0x8 : end of stage 0, next stage 1.
12/10 16:52:49.052 e48 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
12/10 16:52:49.052 e48 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
12/10 16:52:49.052 e48 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
12/10 16:52:49.052 e48 Params: <<< Boolean param 'InitialR2T': received Yes, accepted 1
12/10 16:52:49.052 e48 Params: <<< Boolean param 'ImmediateData': received No, accepted 0
12/10 16:52:49.052 e48 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 8192, accepted 8192
12/10 16:52:49.052 e48 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
12/10 16:52:49.052 e48 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
12/10 16:52:49.052 e48 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
12/10 16:52:49.052 e48 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
12/10 16:52:49.052 e48 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
12/10 16:52:49.052 e48 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
12/10 16:52:49.052 e48 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
12/10 16:52:49.052 e48 Params: >>> ErrorRecoveryLevel=0.
12/10 16:52:49.052 e48 Params: >>> MaxConnections=1.
12/10 16:52:49.052 e48 Params: >>> HeaderDigest=None.
12/10 16:52:49.052 e48 Params: >>> DataDigest=None.
12/10 16:52:49.052 e48 Params: >>> InitialR2T=Yes.
12/10 16:52:49.052 e48 Params: >>> ImmediateData=No.
12/10 16:52:49.052 e48 Params: >>> MaxRecvDataSegmentLength=262144.
12/10 16:52:49.052 e48 Params: >>> MaxBurstLength=262144.
12/10 16:52:49.052 e48 Params: >>> FirstBurstLength=Irrelevant.
12/10 16:52:49.052 e48 Params: >>> DefaultTime2Wait=0.
12/10 16:52:49.052 e48 Params: >>> DefaultTime2Retain=0.
12/10 16:52:49.052 e48 Params: >>> MaxOutstandingR2T=1.
12/10 16:52:49.052 e48 Params: >>> DataPDUInOrder=Yes.
12/10 16:52:49.052 e48 Params: >>> DataSequenceInOrder=Yes.
12/10 16:52:49.052 90c T[8,1]: session 0x8, connection 0x8 : end of stage 1, next stage 3.
12/10 16:52:49.052 90c C[8], IN_LOGIN: Event - LOGIN_ACCEPT.
12/10 16:52:49.052 90c C[8], LIN: T5.
12/10 16:53:21.297 e48 C[8], LIN: recvData returned 10054
12/10 16:53:21.297 e48 C[8], LIN: *** 'recv' thread: recv failed 10058.
12/10 16:53:21.297 90c Tgt: close 'iqn.2012-12.com.demo.spl.com:win7': 0 session(s) opened, 1 more allowed.
Is anyone able to point to me if there is any issue seen based on the log provided and any advise to solve the problem is greatly appreciately.
Thank you.
Kevin
Wed Dec 12, 2012 4:15 pm
Welcome on board 8)
For now I don't see any errors. Maybe we`ll see something if you`ll send the complete log to support@starwindsoftware.com.
Thank you
