Powershell script
johnkapp
Sat Sep 22, 2012 11:06 pm
Good afternoon,
I am working on a Powershell script using StarwindX. The script executes, allocates the drives, but gets an Error 104 Target name "..." is invalid according to RFC 3722! when creating the partner Target. I can manually create the same HA device and target with the same names, but the script gives me the error. I couldn't find anything regarding the errors. I would appreciate any suggestions. It is just the first phase of getting ready for new servers.
$server.Connect()
$masterNode = new-Object Node
$masterNode.HostName = "SAN-1"
$masterNode.HostPort = "3261"
$masterNode.Login = "root"
$masterNode.Password = "starwind"
$masterNode.ImagePath = "My Computer\E\Virtual Disks"
$masterNode.ImageName = "ha-NGITest"
$masterNode.Size = 100
$masterNode.CreateImage = $true
$masterNode.TargetAlias = "ha-NGITest"
$masterNode.AutoSynch = $true
$masterNode.CacheBlockExpiry = 5000
$masterNode.CacheSize = 256
$masterNode.CacheMode = "wb"
$masterNode.HBInterface = "10.3.62.77:3260,10.3.72.77:3260"
$masterNode.SyncInterface = "10.3.6.107:3260,10.3.252.1:3260"
$masternode.SyncSessionCount = "4"
$partnerNode = new-Object Node
$partnerNode.HostName = "10.3.61.66"
$partnerNode.HostPort = "3261"
$partnerNode.Login = "root"
$partnerNode.Password = "starwind"
$partnerNode.ImagePath = "My Computer\E\Virtual Disks"
$partnerNode.ImageName = "ha-NGITestP"
$partnerNode.Size = 100
$partnerNode.CreateImage = $true
$partnerNode.TargetAlias = "ha-NGIBRTestP"
$partnerNode.HBInterface = "10.3.62.66:3260,10.3.66.3260:3260"
$partnerNode.SyncInterface = "10.3.6.104:3260,10.3.252.2:3260"
Add-HADevice -server $server -masterNode $masterNode -partnerNode $partnerNode -initMethod ?lear -verbose -debug
$server.Disconnect()
Mon Sep 24, 2012 2:36 pm
I think that this issue is related to the wrong target name (alias) spelling, as it is possible to see form next string:
And doublechecking with the corresponding RFC:
http://www.ietf.org/rfc/rfc3722.txt
Most likely that the issue was caused because you havent used lower-case only in the target name
Try to use it and everything should work fine.
